Pass. side water leak into the cabin
Old 08-17-2014, 10:42 AM
m1964's Avatar
Default Pass. side water leak into the cabin
After a rain my daughter found water dripping from under the glove box. I was not driving at the time so did not observe it. At the end of the day I checked the cabin filter which appeared to be dry ( but the q5 was driven in outside temp ~86F, so it could have dried out too).
yesterday I removed the A-pillar cover, and pored a gallon of water into the front pass. side sunroof , using a funnel connected to a plastic hose, inserted directly into the drain hole of the sunroof. water came out from under the car, nothing came off the headliner, so I concluded that the sunroof drain is not clogged.
Last week I vacuumed leaves and dirt from under the cowl (which I removed), so the drain hole there was cleared. Poured water from a hose onto the windshield for 5-7 min. -no water leaking into the car. Initially some water came from under the car so I concluded that the drain in front of the firewall is clear too.
when the leak happened, the Q5 was parked nose down about 15 degrees (my driveway).
Any thoughts?
Thanx
Old 08-17-2014, 07:36 PM
SQive's Avatar
Air conditioner drain clogged?
I used to have that problem in a Jaguar. Every time I turned right it would **** on my socks...good times.
Redneck Truck
10
09-10-2010 06:06 AM
yamahapro361
08-09-2003 10:34 PM
Ray Rav
06-08-2003 08:40 AM
Foos
06-15-2001 10:11 AM
clAUDI
05-22-2001 02:32 PM
Quick Reply: Pass. side water leak into the cabin
