Importing Audi CD'S
Old 01-10-2014, 06:40 AM
bob m's Avatar
Default Importing Audi CD'S
I admit to being being totally lost tech wise, but can Audio Cd's be imported into the Jukebox - or elsewhere? I placed the CD in the slot and pressed import and source, but was not able to successfully import that CD anywhere.
Bob
Old 01-10-2014, 07:26 AM
AudiQ5sleeper's Avatar
Bob
you will need to unlock the hidden menu on the MMI and change the settings to allow you to rip CDs and SD card music to the MMI harddrive
Old 01-10-2014, 08:17 AM
bob m's Avatar
Thanks, any idea how to get into that hidden menu?
B
Old 01-10-2014, 09:03 AM
B
you will need a vagcom data cable to unlock this menu.
http://www.audienthusiasts.com/VagComMMI.html
Old 01-10-2014, 12:23 PM
snagitseven's Avatar
I have no problem importing to the Jukebox from an SD card with no mod necessary. I believe the importing from an original store bought CD is what requires the hidden menu mod due to copy protection.
Old 01-14-2014, 08:04 AM
123Audi4me's Avatar
This is correct. SD files can be imported to the harddrive. Also, on a 2013/14, enabling the import CD option in the hidden menu does not work. CD's still cannot be imported.
Old 01-14-2014, 09:04 AM
UK-C200's Avatar
Unfortunately, I can confirm - 2014 with hidden menu enabled - CD ripping not available!
Old 01-15-2014, 09:29 AM
did you change the settings in the hidden menu to allow CD ripping?
Old 01-15-2014, 09:47 AM
UK-C200's Avatar
Yes, I believe I did it correctly as well - if you have a link to something that worked for you, I'm more than game to try again! :-)
Old 01-15-2014, 09:49 AM
JaXeN's Avatar
Solution:
1. Rip your CD's at your computer. (It will rip faster there anyway)
2. Copy the ripped files to an SD card
3. Import your CDs to the MMI via SD card in multiples, rather than one at a time.
Quick Reply: Importing Audi CD'S
