Finally used the spare tire
#11
I'm not talking about a full size spare....
Bob, I'm not sure there is room. Someone said they took out the "liner" and the body pan intrudes too far to allow a full sized spare, which is why I want to get my own eyes in there.
Putting a spare in a car can add 40# to the gross vehicle weight, which impacts the EPA fleet rating for mpg, and adds costs to many things including the suspension, which is built to carry that weight. So I can understand the cheap SOBs omitting something the mass market has no use for.
I mean, most folks can't or won't change their own flat. Although I have a friend who got her license in France many years ago, who said "Do you know they make you show that you know how to change the spare, or you can't get a license?!"
When it is engineers versus cost accountants, you know who will win every time, unless the marketing boys can prove them wrong.
#12
As predicted the kit wouldn't all go back into the correct places. Even the jack is difficult. I managed to pop off and lose a plastic trim rivet. The tool bag? Not a chance. Not that it really matters as the bag can just sit up against the tire.
#13
Bob-
In my understanding, you could not use a donut with AWD. You can't use one with a conventional LSD or Posi rear, and AWD is basically the same thing twice. Which is part of the reason we get something that comes back to the original diameter, to make the differential happy.
Last time I needed a tow I was only ~25-30 miles from the nearest dispatch station. Except, things were busy and they said it would take an hour to arrive. Except, things got busier and it took them two hours to arrive. On an interstate.
But most folks will never complain. The last six or eight flats I've had to deal with were all found in the parking lot. The tows I've really needed...much less convenient.
My friend with runflats who discovered a nice fat bubble in the tire sidewall, was "only" 100 miles from home. But got stuck overnight where she was, because who'd going to risk a blowout driving with one of those? And of course, the two new tires (for the axle pair) had to be shipped in.
How inconvenient this stuff is, depends on how you feel about wasting a couple of days and dollars, versus having the spare changed in 15 minutes.
#14
The donut spare whould be same diameter
Bob-
I need to look at that spare tire well cutout tomorrow, I thought it had a much larger diameter than the collapsable spare.
#15
I feel your pain relocating those items....
I had the same problem qith my 1997 A4, I need to go to the delaer and look at a new one to see how the jack folded up correctly. My next Audi I took a lot of photos where everything was and did it on my 2014 Q5 also. Now it's simple to relocate the proper place/way.
#16
Coat the wheel hub with anti-seize compund
I blew out a tire and didn't know about the valve on the hose that needed to be closed. the pump was running and nothing was happening. I let this go on for way too long. I ended damaging the paint on the rocker panel because the jack is so poorly designed and has to be placed precisely. I got everything done up to removing the tire from the hub. The rim was fused to the hub because of salt. I couldn't get it off. I called Audi Roadside finally. It also didn't occur to me that there was an outlet in the cargo area. I ran the wire up into the car to the console area.
If you live in a salty area, go to Harbor Freight or somewhere with cheap tools and get a rubberized mallet. You may need to smack the wheel a bit to get it off.
That experience was truly a huge P.I.T.A. BTW, Audi sent some guy in a beat up old mini van who would have had no clue how to inflate the tire or where it was even located. READ UP
#17
Good comment, tomorrow extra valve stems in Q5
"remove the tire valve,"
FWIW, I wouldn't suggest that. If you remove the valve core, there's a good risk of losing it. And if not losing it, dropping it or getting dirt, pocket lint, whatever on it, and then the o-ring won't seat properly. Or, it may simply tear from being unseated and reseated.
Simpler to just KISS, inflate the tire with the valve core in place, the way it is designed to be inflated. If the tiny factory pump is inadequate for that...there are plenty of bigger faster stronger pumps on sale all the time.
And if you live someplace where there is winter...do you really want to screw around with valve cores at night on the side of the road in slush and snow? Nah. KISS.
One day I'm going to pull out the trim and see whether a full wheel can be coaxed in there.
#18
Recollpsing the spare has its problems...
It is known that once the spare is inflated and deflated the tire "may" not seat to the rim properly and not reinflate next time. A lot of owners like to try out the spare/compressor to get familar with the operation and test inflate the spare. They then deflate it and try again and have found the tire will not seal to the rim and thus no inflation
#19
You'll see as the tire ages, the fold is harder to "pop" thats why removing the tire valve helps to inflate it up to a point then putting the valve back to finish the job. Worst case the valve core is inexpensive to replace if it leaks.
