Getting ready for DIY
#11
Two obvervations:
** The dipstick seems pure plastic. I don't think it's a good idea to leave it in the car.
** The dipstick seems quite accurate. In MMI, the oil level is at MAX. On the dipstick, oil level is right at MAX.
(3) Oil extractor:
Any good tips on which model to choose?
(3) Oil extractor:
2) Dealer measured this dipstick against their set-point adjustable service dipstick. It's the same.
3) I use the Mityvac 7400 - It was great until about the 10th oil change (conventional oil on my other cars)....started leaking at the top handle. This is a common complaint. I know just put the whole thing in a 5-gallon bucket and place a large freezer bag over the handle to contain the spray).
#12
Didn't think I'd need to the dipstick so soon after only 14K miles on the odo. Will never go without it now.
#13
I'd also vote for the MityVac. I had actually ordered a different brand online, which used a "ball" instead of the tall cylinder. I figured the ball was less likely to tip over, and easier to carry over to disposal. Except, the assembly was a bit Mickey Mouse, a critical part was missing, so back it went for the MityVac like I've used before. Which pulls a very robust vacuum and takes up less storage space.
I've heard the leak comment before but in years of using several of these, never had it leak. Maybe there is something about the seal that melts in some ingredient in some of the oils? Maybe MityVac would warranty the leaking part?
I do use it like I'm working with hazmat though. The plastic tubes like to whip around and throw oil whenever you remove/move them. So I handle with care, wipe with paper towels, wrap with more paper towels to store the whole thing in a heavyweight plastic trash bag that stays in the box, to make sure any mess is trapped in the paper towels and contained. Oil drain pans can make a mess too, just needs a little different handling.
#14
Regarding the leaking - I have heard, though can't recall at the moment, that certain oil types can cause the containment failure. Have also heard that Mityvac, if contacted directly, have been good about replacing parts.
#15
If you have an air compressor there are a few options out there for air powered extractors. Personally I like to drain it out the bottom. Gives you a chance to check out whats going on under the skid plate. Also I have to pull the skid plate to change the filter on both my Audi's anyway.
#16
Thanks for all the tips.
Here are the rest:
(3) Mityvac 7201:
I haven't opened it yet. But from the box, it's quite big than expected.
(4) 36mm oil filter socket
Cost so far
(1) oil filter: ~$16 online
(2) Dipstick: ~$25 online
(3) Mityvac 7201: ~$95 online
(4) 36mm socket: ~$8 Pepboys
Total: $144
Ready for action? Anything else? (I do have other regular tools)
Here are the rest:
(3) Mityvac 7201:
Cost so far
Total: $144
#17
Here are the rest:
(3) Mityvac 7201:
Cost so far
Total: $144
Here are the rest:
(3) Mityvac 7201:
Cost so far
Total: $144
abel2pt8
06-02-2004 06:06 PM
M what?
12-09-2002 09:13 AM
PDXA4
04-09-2002 02:50 PM
