Send to Car - google map and iphone
Old 08-12-2014, 08:15 PM
imdakine1's Avatar
Default Send to Car - google map and iphone
I was wondering if we can send to car from our smartphone? So far I've begun sending to car from my macbook but could imagine how convenient it would be to send it directly to the car from my iphone or ipad. Thoughts?
Old 08-12-2014, 08:18 PM
arrtewwx's Avatar
There's an app for iOS at least - MMI Connect. It's a little clunky, but you can send to car via the map interface / online destinations.
Old 08-13-2014, 07:15 AM
ser968's Avatar
I read somewhere about this app and downloaded the 'test' and it worked - it is called 'Send to Car' in iOS and it is a free app that you download to test the connection. If it works, you then buy the app to use it. I have not purchased the app, so I can't speak to its interface and/or ease of use.
Old 08-13-2014, 07:40 AM
Q5 Bob's Avatar
I have the Send To Car App for Android devices. It works well and is free, at least for Android.
Old 08-13-2014, 08:49 AM
Cadx6's Avatar
If you're using an "i" device - do a search in the App store for "MMI Connect". It's an Audi app that works perfectly on iPhone, iPod, or iPad. I use it all the time to store destinations & then when I get in the car all I have to do is go to Destination > Online Destinations > Find Destination From My Audi Account. Anything you've sent to the car will be listed there. The app is free & has a few other functions such as Car Finder & Music Stream.
Old 08-13-2014, 09:40 AM
AudiWorld Expert
ex-quattro PETE's Avatar
Based on its description, this app was designed for the newest MMI generation, such as the one in the new Audi A3. Are you saying it works with the older MMI systems such as the one in the Q5, too?
Old 08-13-2014, 11:17 AM
centurion70's Avatar
For iOS, I highly recommend the app called Send to Car. The procedure for using it is a bit odd, but very effective and efficient:
1. Locate your destination in the iOS Maps app.
2. Within Maps, select "Directions to Here".
3. [this is the really strange part] Change your mode of travel to public transportation (press the little bus icon).
4. Press "Route"
5. Select "Send to Car" from the list of apps. This sends the destination to your MyAudi account.
6. In your vehicle, use MMI to pull up your list of MyAudi destinations, and you will see your newest entry.
Six steps sounds like a lot, but it is actually very quick and smooth, and the destination appears in your MyAudi account very quickly. The whole process only takes a few seconds.
The Send to Car app takes advantage of the fact that the iOS Maps app does not provide public transportation routing. Instead, Maps will send the destination to a different app of your choice to provide the routing. When you select Send to Car from the list of apps, it automatically sends your destination to your MyAudi account.
Old 08-13-2014, 11:39 AM
Cadx6's Avatar
I use it with my 2013 Q7 with MMI 3G (?).
Can't see how any other app could be simpler - especially since it's designed by/for Audi.
Old 08-13-2014, 02:38 PM
imdakine1's Avatar
I saw the app in the app store and Downloaded the test app to see if it would work etc... The test app requires you to send a "dummy" Washington DC address to your car. It did work. I'll try the Audi Connect App first.
Does anyone know why the addresses I send to my car are sent but doesn't appear to keep the label I provided. I now have a number of addresses but only a couple include the name of the location the others are just addresses.
I chose to label the address such as dentist, etc....
4. Press "Route"
Old 08-13-2014, 04:42 PM
stash64's Avatar
Do you need Audi Connect for this to work or does it communicate thru the NAV link ?
Quick Reply: Send to Car - google map and iphone
