***** Lowered Q7 Thread *****
#159
AudiWorld Expert
If you have adaptive air suspension all you need is a vagcom / vcds or you can get the h&r lowering module. If you have standard suspension you should go with coil over suspension upgrade. Lowering springs will result in a pogo stick effect where your Q7 bounces down the road.
The Orca Black Q7 with California plates has spacers installed. If I recall correctly they are 23mm Front & 30mm Rear. (The most common is 18mm Front 23mm Rear.)
