2006 q7 white smoke
2006 q7 white smoke
hi all my first post here as just brought car .well what it is is i just brought an q7 with 108000 miles on her and problem is it smokes a lot white smoke if i sit there for a few mins with engine running then drive off i get loads of white smoke i had a diagostnic check today and all was great no faults the guy reckons it could be seals in turbo letting oil into the exhaust anyone else had this problem many thanks rick
White smoke means water. Blue smoke at start up is oil from bad valve seals. Blue smoke from a hot engine is worn rings.
White smoke at start up is usually condensation in the exhaust system. It could be a coolant leak. Check what you have after driving. It could be normal. If it continues, have a shop perform a compression check of the engine.
Not good. It sounds like a coolant leak into the cylinders from a blown head gasket. Do you see bubbles in the coolant reservoir?
I agree. (DO NOT DRIVE TOW IT ) $$$$$
White smoke occurs when raw diesel comes through the exhaust completely intact and unburned. Some causes of this include…
Faulty or damaged injectors
Incorrect injection timing (could be a worn timing gear or damaged crankshaft keyway).
Low cylinder compression (eg caused by leaking or broken valves, piston ring sticking, cylinder and/or ring wear, or cylinder glaze)
When white smoke occurs at cold start, and then disappears as the engine warms up, the most common causes are fouling deposits around piston rings and/or cylinder glazing. Use of our Flushing Oil Concentrate and FTC Decarbonizer address these respective problems.
Water entering combustion spaces will also create white smoke. Faulty head gaskets and cracked cylinder heads or blocks are a common cause of water entry, and are often to blame. Unfortunately, expensive mechanical repair is the only proper solution here.
PT2
White smoke: White smoke is caused by water and or antifreeze entering the cylinder, and the engine trying to burn it with the fuel. The white smoke is steam. There are special gaskets (head gaskets are the primary gaskets) that keep the antifreeze from entering the cylinder area. The cylinder is where the fuel and air mixture are being compressed and burned. Any amount of antifreeze that enters this area will produce a white steam that will be present at the tailpipe area.
If white smoke is present, check to see if the proper amount of antifreeze is inside the radiator and the overflow bottle. Also check to see if antifreeze has contaminated the engine oil. You can look at the engine oil dipstick, or look at the underside of the engine oil filler cap. If the oil is contaminated with antifreeze, it will have the appearance of a chocolate milkshake. Do not start the engine if the oil is contaminated with antifreeze as serious internal engine damage can result.
How did antifreeze get in the oil or cylinder in the first place? The engine probably overheated and a head gasket failed due to excessive heat, thus allowing antifreeze to enter the cylinder (where it is not meant to be).
PT2
well the car went in to audi today and what thay reckon it could be is possible sticky e g r valve or it could be bad diesel but thay checked car all over and cant find anything wrong
Hi all ,took my car out today and and low and behold there it was again loads and loads of white smoke and this is when the engine is hot audi said my coolents are all fine but the car drives superb could it be turbo seals ?
Audi first start smoke
Hi all not sure weather this is much to worry about but I have a Audi Q7 sport line v6 I’m have trouble starting first thing in the morning it finally starts if I turn ignition of and on a few times. I have changed glow plugs also new turbo just fitted due to actuater fault and veins in turbo not good also changed to fuel filter yesterday been putting the better fuel in diesel but same problem the computer doesn’t throw up any codes do you think anything to worry about or normal behaviour at 127k miles
thanks lee
thanks lee
gamblerS4
13
06-15-2005 10:52 AM
Diztek
10
12-06-2004 01:21 PM
