2011 Q7 trailer hitch install
#41
Greetings all...am. ~85% done with installing the OEM hith and brake controller on my 2010 Q7 TDI. Thank you PCOliver! One thing I am confused,on is how to get access to the to where the brake controller rests? Removed the right side cargo tie downs and the piece they rest on, removed the fuse panel, and could tug out slightly the carpeted panel an inch or two- no more. I could not remove anything else. So...my brake controller is resting below in a vacant area...but is semi loose. Did I miss something? Thanks much!
#42
Well I have an issue that I cannot figure out. Installed the Audi tow hitch and ECU module. Had my local Audi dealer code the vehicle yesterday. Still cannot get the brake lights on the trailer to work. Tail lights, turn indicators, emergency flashers all work. Checked all connections and all looks good. Tried 2 different trailers with the same results. Any ideas?
#43
I have plastic tabs in the way, so I am unable to slide it in where its supposed to go, so I believe it's needs placed from above. I attached a picture with an orange tool where I believe it goes. Above tool is plastic bar I can't figure out how to remove (after removing the tie down hook flooring). 2d slot below tool is where the ECU is now.
PCOliver's post showed the plastic bar in photo removed...how do I do that?
#44
One more of bar from top. Orange tool resting on it. Can't get it off even with the fuse panel cover removed and surrounding panel pulled out. And sorry for the portrait orientation pics. Thanks much!
#45
You do not need to remove the plastic panel that your tool is resting. Open the fuse panel cover on the right. The ECU module can be installed by going through the opening that is now evident after removing the fuse panel cover. It is a tight fit.
#46
Hope this helps others.
