Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Anyone ever use generic TPMS?
Old 07-28-2012, 02:16 PM
sshu's Avatar
Default Anyone ever use generic TPMS?
I found these on ebay but am wary of the generic TPMS system. It's more than 1/2 of the price of the regular ones. Any other leads for other sellers of TPMS?
Thanks,
Scott
Old 07-28-2012, 03:29 PM
sshu's Avatar
Sorry, here is the link,
http://www.ebay.com/itm/TPMS-Tire-Pr...9cb34f&vxp=mtr
Old 07-29-2012, 04:34 AM
Jusforfun's Avatar
??? why do you need those? Doesnt the 2012 Q7 use differential wheel speed to monitor tire deflation via brake sensors instead of those sender units.
Pretty sure they are for older MYs of Q7
Old 07-29-2012, 11:31 AM
sshu's Avatar
interesting. I found this on Audi's website,
http://www.audiusa.com/us/brand/en/t...S_Systems.html
Does this confirm that there is no tpms unit in the tire? I can simply buy any rim/tire set that fits?
Old 07-29-2012, 12:59 PM
weth's Avatar
There is no TPMS device in the wheels of a 12 Q7. It is all software controlled through reading from the anti lock brake/traction control system. Basically it monitors RPM and vibration from each wheel to look for evidence of air loss.
Old 07-29-2012, 07:18 PM
Shoe's Avatar
So if I change to different size tire/rims I don't need to worry about needing a TPMS unit anymore? Just install the new rims and go? Sounds so simple.
Old 07-29-2012, 09:10 PM
weth's Avatar
Just install new rims and go.
Final confirmation - there is no TPMS unit anymore.
Old 07-30-2012, 06:12 AM
Jusforfun's Avatar
You go to MMI and reset TPMS for new set. it takes a few minutes to update then you confirm. Just the same as when you want to change your running pressures on existing tyres/tires.
The link provided in sshu's second post does list 2012 Q7 but it is wrong. They may get some sales and the system will still work just the valve units will not serve any function.
Old 07-31-2012, 06:29 AM
Shoe's Avatar
Thanks for the help, appreciated
CMS4
04-08-2004 10:28 AM
D3AeighT
03-21-2004 04:10 AM
Phil type 951
Motorsport Discussion
04-15-2003 07:44 AM
bugbbq
12-07-2000 07:43 PM
SAF
06-14-2000 02:41 PM
Quick Reply: Anyone ever use generic TPMS?
