Keyless break in
Keyless break in
So sometime last night, my Q7 was broken into in my driveway, with the thief most likely using a keyless remote signal booster. I don't keep anything of value in the car, so nothing was taken, other than possibly a roll of quarters. I was the last one to drive and definitely locked the doors afterwards because I recall seeing the led on the drivers door flashing when I was rolling out the garbage. Both keyfobs were in the house, and the drivers seats were in position for my wife, who hasn't driven the car in at least a month.
I was wondering if there's a setting in VAG or MMI that disables keyless unlock only, but maintains lock and ignition functionality.
Thanks!
Thanks!
AudiWorld Expert
i am not sure of any setting that lets you choose which functions of the passive keyless entry are enabled or disabled but you can completely disable the system but you will have error messages when you scan the vehicle (not on the cluster).
if you manual lock the the door with the key blade i believe that overrides the keyless entry as well. the doors will only open again with the key unlocking the cylinder in the door.
I was thinking that keeping the key in an anti-static bag like the kind computer hard drives are shipped in might work, but it doesn't. Aluminum foil does work if it's completely wrapped. I'll probably find a small box and line it with foil to keep the keys in when I get home, or some sort of metal pail.
There is a solution to this problem involving sensing the additional time lag that occurs when the key is a long way from the car (one ns per foot). Hopefully Audi will add that feature someday... or maybe sooner to make amends for dieselgate.
AudiWorld Expert
the distance needed for the key to be inactive isn't that far. providing your vehicle is not within that distance it should not allow the door to be opened. if i stand by my front door and my wife tries to unlock in the driveway the vehicle will not open. i believe the threshold is approximately three feet.
AudiWorld Expert
The car is constantly sending a signal looking for a key. The thieves use a device, an amplifier, that strengthens the signal from the car, causing the key to respond even if it's far away. The same device picks up the key's response and sends it back to the car. Once the door is open the same trick lets the thief start the car. He can drive away, but can't restart the car later.
