MMI dead, not sure where to go next
I've spent several weeks trying to get my MMI back alive and would appreciate some tips on next steps. I had sunroof drain water damage on the amp, so I sent it off to be repaired. In the meantime, I bought a couple of fiber loop back adapters. Putting those in place of the amp, Sirius, and radio units (the three in the rear where I had water) didn't fix it. The CAN gateway is the fault found, open circuit. I've Googled that to death and can't determine where to look for that.
So with the repaired amp in, here are my scan results:
Control Module Part Number: 4F0 907 468 F
Component and/or Version: GW-BEM 4CAN-M H06 0022
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway ERROR ERROR
07-Control Head ERROR ERROR
0E-Media Player 1 ERROR ERROR
1E-Media Player 2 ERROR ERROR
77-Telephone ERROR ERROR
47-Sound System ERROR ERROR
56-Radio ERROR ERROR
37-Navigation ERROR ERROR
0F-Digital Radio ERROR ERROR
Saturday,02,July,2016,12:45:32:16963
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.4.1
Data version: 20160216
Ross-Tech: Home
Chassis Type: 4L (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
52 56 62 65 69 6C 6D 6F 72 76 77
Mileage: 179450km-111505miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (BHK) Labels: 03H-906-032-BLV.lbl
Part No SW: 03H 906 032 DA HW: 03H 906 032 G
Component: Q7 3.6-FSI-LEV2 G 3234
Revision: 5CH05--- Serial number:
Coding: 0001175
Shop #: WSC 31414 790 00001
VCID: 64C7D287A719FC1EFA-8030
1 Fault Found:
001056 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 179308 km
Time Indication: 0
Date: 2016.06.26
Time: 15:32:28
Freeze Frame:
RPM: 2571 /min
Load: 49.0 %
Speed: 110.0 km/h
Temperature: 88.0°C
Temperature: 37.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.097 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4L0 910 156 E HW: 0AT 927 156
Component: AG6 0AT 3,6 FSI USA 0020
Revision: --H04--- Serial number: 4049491
Coding: 0000002
VCID: 2B5579BB8A477366FB-807E
No fault code found.
Address 03: ABS Brakes Labels: 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 D
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0099345
VCID: 295983B380BB617609-807C
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601150906
Coding: 0000131
VCID: 25418F83ECA345162D-8070
Subsystem 1 - Part No: 4F0 910 132 J
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 B HW: 4L0 820 043 L
Component: KLIMABETAETIGUNGH07 0040
Revision: 00---013 Serial number: 00000000182151
Coding: 0524326
VCID: 2345919BE297BB2643-8076
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H21 0310
Revision: 00000000 Serial number: 4F0907279
Coding: 0011123
Shop #: WSC 07408 444 105096
VCID: 346762C757792C9EAA-8060
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H15 0100
Coding: 00064792
Shop #: WSC 07408
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150317
Shop #: WSC 07408
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD093PZ-
Coding: 0014131
Subsystem 1 - Part No: 4L0 910 339 A
Component: BF-Gewichtsens. H03 0030
Subsystem 2 - Serial number: 6332QSME780C1059H
Subsystem 3 - Serial number: 6342QSME2505021E5
Subsystem 4 - Serial number: 6352QSME6C29264BT
Subsystem 5 - Serial number: 6362QSME774C2E5D%
Subsystem 6 - Serial number: 63734SME7D284B25A
Subsystem 7 - Serial number: 63834SME75063B775
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90026082010014
Coding: 0002142
VCID: 275D858B96AF57061F-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels: 4L0-920-xxx-17.clb
Part No SW: 4L0 920 981 S HW: 4L0 920 981 S
Component: KOMBIINSTR. H06 0133
Revision: 00100000 Serial number: 9IF41TL88
Coding: 8B9663040100D705020201
VCID: 408F3E17D3C1803E3E-8014
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 F HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0022
Revision: LA602018 Serial number: 1800L0872780B0
Coding: 000003
VCID: 326B64DF6D6D22AEB8-8066
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0080
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 196
Mileage: 175522 km
Time Indication: 0
Date: 2016.05.26
Time: 09:24:49
Address 1E: Media Player 2
Cannot be reached
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001001118884
Coding: 00581300000011110000
VCID: 31696BD3686B19B6C1-8064
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000100146546
Coding: 010D07205E40440004
VCID: 4683280FF1E5AE0E04-8012
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 F HW: 4L0 907 289 C
Component: Komfortgeraet H08 0060
Revision: 0060 --- Serial number: 01136482630000
Coding: 7632925
VCID: 336561DB52772BA6B3-8066
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000042511
Coding: 0012001
VCID: 5EB3E06F8975D6CE2C-800A
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000100150480
VCID: 45812F03CCE3A5160D-8010
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000100143816
Coding: 010C07204040230004
VCID: 4385311BC2D79B2623-8016
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900079698
Coding: 0062424
VCID: 224B949FFD8DB22E48-8076
Address 69: Trailer (J345) Labels: 4E0-907-383.clb
Part No SW: 4E0 907 383 G HW: 4E0 907 383 G
Component: Anhaenger H07 0060
Revision: 2A002002 Serial number: 00000113008532
Coding: 0200000000000000
VCID: 2E5370AF7955064EDC-807A
1 Fault Found:
16355 - Control Module - Watchdog Timer
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 255
Reset counter: 255
Time Indication: 0
Date: 2063.15.31
Time: 16:03:63
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J8741DO
Coding: 1021201
VCID: 24479287E799BC1E3A-8070
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 C
Component: ValeoHeckdeckel H25 0290
Revision: --H25001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD7BAA74FC9B45EB2-8038
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD06.08.08--H25001001B0178ÿ
Subsystem 4 - Serial number: 1B0178ÿ
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 003812969-----
Coding: 0003595
VCID: 2643888F91A54E0E24-8072
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE16_SKB09H10 0200
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE16_SKB09H10 0200
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE16_SKB09H10 0200
2 Faults Found:
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 200
Mileage: 177517 km
Time Indication: 0
Date: 2016.05.30
Time: 18:41:31
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 200
Mileage: 177517 km
Time Indication: 0
Date: 2016.05.30
Time: 18:41:31
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100143819
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 K HW: 4F0 919 283 K
Component: Parkhilfe 8-Kan H12 0100
Revision: 00H12000 Serial number: 69840822001801
Coding: 0231346
VCID: 2C577AA78F49745EF2-8078
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:22)--------------------------
Thanks for looking.
Ross-Tech: Home
Coding: 0001175
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 179308 km
Time Indication: 0
Date: 2016.06.26
Time: 15:32:28
Freeze Frame:
RPM: 2571 /min
Load: 49.0 %
Speed: 110.0 km/h
Temperature: 88.0°C
Temperature: 37.0°C
Voltage: 14.097 V
Coding: 0000002
Revision: 00H30001
Coding: 0099345
Coding: 0000131
Cannot be reached
Coding: 0524326
Coding: 0011123
Coding: 00064792
Shop #: WSC 07408
Coding: 00150317
Shop #: WSC 07408
Cannot be reached
Cannot be reached
Coding: 0014131
Coding: 0002142
Coding: 000003
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 196
Mileage: 175522 km
Time Indication: 0
Date: 2016.05.26
Time: 09:24:49
Cannot be reached
Cannot be reached
Coding: 7632925
Cannot be reached
Coding: 0012001
Address 56: Radio
Cannot be reached
Coding: 0062424
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 255
Time Indication: 0
Date: 2063.15.31
Time: 16:03:63
Coding: 1021201
Coding: 0003595
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 200
Mileage: 177517 km
Time Indication: 0
Date: 2016.05.30
Time: 18:41:31
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 200
Mileage: 177517 km
Time Indication: 0
Date: 2016.05.30
Time: 18:41:31
Coding: 0231346
Cannot be reached
Thanks for looking.
What errors do you get with the loop back connector in place?
Is this just one connector you can use to bypass all three items?
It looks to me that one of the items you have put back in the bus is dead an dropping the whole loop which is why it's showing a whole raft of items.
I don't know where the start and end of the bus is but I guess it's at the front and probably a box under the carpet in the front footwell.
I put loopbacks on the Sirius and radio units, no change.
I want to start here:
1 Fault Found:
011 - Open Circuit
but can't find exactly where this would be. Anyone know? For as popular as all this is, the documentation is terrible. Guess I got spoiled with all the FAQs on VW/e46 I've used through the years. Thanks.
1 Fault Found:
011 - Open Circuit
Still nothing
Thanks for this Edd. I put a loopback in front of the control module and still nothing. No one seems to know how the fiber is routed around the vehicle. I'm about ready to rip all of it out and put in a new system. Audi wants $500 just to try and find the fiber break, and I'd rather put that towards a new system. Stinks to have to live without basics like setting my clock to the correct time. Really disappointed in Audi here.
Finally found a reputable "Euro" dealer here who for $300 checked all connections. Turns out it was my Nav unit. The one thing I'll never use. I bypassed it and everything came back to life. Just kicking myself as I'd tested the other 3 devices right there.
I'm still frustrated at this needlessly complex tech and how little info there is out there about it. Such is life with Audi I guess.
RPortela
12-16-2009 05:01 AM
Pelican Pete
09-29-2000 09:50 PM
