Q7 starting Problems
#11
If it starts right up when you jump start it then it could be something that is draining the battery slowly over time. Maybe a relay, a switch, or even a door handle with keyless entry for example. If your able to, try removing some fuses to non essential components and see what results you get. Just a suggestion and probably something I'd try.
#12
The battery is brand new mate, i had it replaced about 6 weeks ago, for the first couple of weeks it was fine but then the problem came back again
#13
#14
If the shop was able to code your new battery via the VAG-Com then I'm quite certain they'll be able to perform a full scan and read any codes that are stored. Clearing the codes itself will most likely not solve the problem but it will lead you in the right direction as far as indicating what could be failing and possibly draining the battery, if that is the case. Once the codes are cleared, if/when the problem happens again, have the shop do another full scan to see if there is a code that keeps coming up. Hopefully that'll get you closer to your issue. Good luck and keep us posted!
#16
#17
Yes, he should be able to clear the codes but that will not in itself cure the fault, it simply means that you have a clear record of faults so you know you are not looking for a fault which occurred before the new battery was fitted.
If the problem continues, which it probably will, have the faults downloaded again and then work from there because they should point towards the actual problem.
It may well be a faulty alternator or charging circuit.
#18
#19
Hey mate - Had a similar issue on my 2--7 4.2 V8 when I had it. Days of no issue, then just dead and a jump would do it. Its gonna sound crazy but i had water seeping into the back where the Bose amp is from the sunroof lines. Thats water was shorting things out, drian the battery then dry up. I ended up forking out 1200 for a new bose amp and seal the drains. No more drained battery. I'd check for water in the spare wheels well too.
#20
Audi batery coding
