Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
2008 Q7 4.2L S Line Premium Cloudy window trim and roof rack rails
Old 05-28-2013, 09:25 AM
Q7 Newbie's Avatar
Default 2008 Q7 4.2L S Line Premium Cloudy window trim and roof rack rails
Hi Guys, brand new Audi owner. I have had this Q7 for a month and I have a cloudy white water spot type substance on the window trim and metal factory roof rack rails. Its driving me crazy! Have tried mothers aluminum polish and chrome polish, nothing takes this crap off, unless I am not generating enough heat with elbow grease. I have seen a few other posts on this issue, but I am still unclear if the metal window trim on the '08 is polished Aluminum or a chrome type finish. The metal roof rails also "appear" to be a polished Aluminum, but I am not certain. Dealership doesnt seem to me much help. Loving the vehicle, hating the cloudy spots on the metal.. Has anyone tried a 0000 steel wool with a polishing compound? I'm a little concerned that will scratch and then not polish out... many thanks for any thoughts! Dan
Old 05-28-2013, 09:41 AM
iNfiNkC's Avatar
I had a similar issue with my xc90, it had aluminum trim around the windows. I went to one of those auto washes and the chemicals ate the trim up. I tried everything to try and polish them. Landed up contacting the carwash and filing a claim, took awhile to prove but in the end they paid to have the trim replaced.
Old 05-28-2013, 10:26 AM
scottr13's Avatar
Do you mean like water marks where the rain has dried in? I get this on my Q7 and just wipe it off with Autoglym glass polish when doing the windows but it comes back the next week after its been raining
Old 05-28-2013, 10:38 AM
Q7 Newbie's Avatar
That's what it looks like but I can't polish it out, I will try a glass cleaner but its more than water spots with a dulling white haze. It may have been from the previous owner or the dealer using something on the car to clean/detail it but it looks like hell... Will try the glass cleaner and let you know. Thanks.
Old 05-28-2013, 01:15 PM
10 Bulls's Avatar
i have an 08 Q7 S-line that had exact same problem on trim, roof rails & running boards... used Steel Wool 0000 with P21 Finish Restorer and everything looks brand new again. Also used this on what looked like unrepairable exhaust tips (completely black/blueish caked-on soot) which also now look brand new again!
ordered both on ebay. highly recommend it!
Old 05-29-2013, 07:28 AM
Q7 Newbie's Avatar
10 Bulls - Thanks very much, will try this and advise - appreciate the info!
Old 09-10-2014, 07:40 AM
claybartel's Avatar
Hi Guys,
I have the same question as Q7 Newbie, what worked? I have been considering trying the 0000 steel wool with a polish but was afraid of ruining the rails and window trim also. thanks
Old 09-10-2014, 10:18 AM
AudiWorld Expert
iconoclast's Avatar
you would probably have less headaches and more success with matte black vinyl wrap around the trim... some people have used plasti-dip but i think it's kind of ghetto to start spraying your car with this nonsense.
Old 09-10-2014, 05:22 PM
cuatrokoop's Avatar
Most of the alu trim I've seen on Audis does this, it is oxidation. If there is a clear anodizing on the trim, the steel wool and polishing agent may remove it, so you will likely be doing that job multiple times. If it wouldn't be such a problem, you could clean it and have it shot with clear coat or Nyalic. Nyalic actually now makes kits for the DIY'er. At my previous job, it was used over whole pieces of equipment, just masked off the glass and tires and literally everything else was sprayed.
Old 09-10-2014, 05:26 PM
cuatrokoop's Avatar
Here's a link:
Nyalic® Touch-up Kit I :: AUTO/TRANSPORTATION KITS :: Nyalic® Clear Surface Prote ctant
Yes, I know I responded to an older portion of this thread.
mcdream
24
08-22-2013 06:31 AM
derumeaux
Q7 MK 1 Discussion
07-03-2009 10:05 AM
progolfer_20
Audi 100 / A6 (C4 Platform)
09-10-2006 07:10 PM
HX_Guy
09-21-2004 03:15 PM
MachineMan
Audi allroad
10-21-2003 08:38 PM
Quick Reply: 2008 Q7 4.2L S Line Premium Cloudy window trim and roof rack rails
