What is the largest SD card the MMI-3G+ system will acknowledge?
AudiWorld Expert
If I recall correctly it used to be 2GB on the previous generations. Is that still the limit or has it been raised?
I have two 32gb cards in mine - they work great. They have to be formatted FAT32, as 32gb is the normal upper limit for FAT32. I tried a 64gb card and it worked - you have to use a work-around to format the larger size. The 64s worked but were REALLY slow to mount to the system. Instead I run a 500gb hard drive in the glove box.
ltooz_a6_a8_q7
Q7 MK 1 Discussion
09-05-2017 10:31 AM
ltooz_a6_a8_q7
09-05-2017 10:29 AM
muski
10-03-2008 04:10 PM
