Smell of gas
Smell of gas
My Q has developed a gas odor after turning off the motor. It is only apparent in the garage or in an enclosed area. It cannot be smelled outside. It does dissipate after about an hour. There is no fuel leakage or warning lights and the dealer, of course, can't duplicate. Does anyone have an answer?
Re: Smell of gas
Yep, had the same problem. They had my car for several days and couldn't duplicate it. I think the problem is that their garage/workshop area is too wide open. I bet you its happening to more people but its just not being noticed. If you don't happen to go back into your garage after the car has sat for a couple of minutes, but within an hour or so, you would never notice.
Re: Smell of gas
Exactly. Have you had any problems with the car as a result of this? I'm a little worried as I'm about ready to take a rather extensive trip in the Q. My garage is not heated and it all started when we had some really cold weather. I don't know if there is a connection or not. What really gets me is that the general manager took the car home and said he couldn't smell anything. Go figure.
There was a post on the A6 forum that is similar....
<ul><li><a href="https://forums.audiworld.com/c6a6/msgs/54487.phtml">https://forums.audiworld.com/c6a6/msgs/54487.phtml</a></li></ul>
No problems at all...
I think it is not just related to the cold. I first smelled this a few months ago, but didn't connect it to the Q7. After all, you can only smell it during that narrow band of time after you park it. Car has run fine and we haven't had any problems, so I think you are good. My dealer said they checked the fuel lines and there was no leak. The smell seems to be the strongest in the driver's side rear wheel well.
Nickdc955i (07-29-2019)
Re: No problems at all...
Good. Glad to hear there have been no problems. It sure is weird.
Yesterday, the odor went away, but today it's back. Same outside temp both days so I'll have to agree that it's probably not temp related. I can't determine where it's coming from as the whole garage smells. Hard to believe no one else has ever posted with this problem.
Q7 GAS SMELL
We are experiencing the same smell in our 2008 Q7 4.2 and have been for sometime, but we have our mower in our garage too, so I always blamed it on the mower. I pinpointed it tonight. It's it VERY strong on the rear driver's side wheel well. I notice it mostly right after pulling into my carport. But sometimes even smell gas hours after turning car off. This could be very dangerous!!! The smell is so strong, One spark could probably ignite the fumes.
Other Suggestions
Hey All! New (used 07) Q7 owner and I'm noticing the same smell. I want to narrow down the issue before taking to dealership. Only 1 in my area and they were SUPER rude when I went in for an inspection.
TIA
TIA
It's probably the gas cap rubber seal. Mine was cracked and was allowing black mold like stains to grow all around the gas filler area and backside of the fuel filler door. No doubt due to gasoline fumes slowly leaking out!
