VagCom Changes and Modifications MMI-3G+...
#53
AudiWorld Expert
Engineering Mode / Green Menu:
Audi MMI 3G hidden green menu
version
export version info
export onoff info
export EPromFlags info
Start Script
Train name
versionmu
versionru
versiondu
versionaudio
versiontelephony
versionmost
versionbt
addressbook
is OADB cancelling active
copy db to sdcard
copy tef to sdcard
delete db
aevtest
scan for jobs
fakeaudiosettings
functiontest
numlisttest
scripts
slidertest
tabletest
fakeextra
audiomanagment
volumerangers
Entertainment lowering
Entertainment min
Entertainment max
SDS min
SDS max
Navi min
Navi max
Telephone min
Telephone max
Traffic min
Traffic max
audiomisc
Mute pin state
Mute behavior actual
Volume max
Muting reason
lenses timer disp. 1 (100ms)
lenses timer disp. 2 (100ms)
inputgainoffset
MW
FM
MUCD
CDC
DAB
DVBT
TV
SDARS
TIM
MU AUX
MU AUX ADAPT
MU DVD
MU FPP
MU BT Device
mme
Activate AMFM cluster
Deactivate AMFM cluster
Activate CDC cluster
Deactivate CDC cluster
Activate DVDC cluster
Deactivate DVDC cluster
bluetooth
Link key restruction active
browser
Delete Old Non-ISO boardbook
bths
bths 1
byhs 2
car
carcodingvehicle
steering wheel der.
behicle derivat
configuration line
vehicle model line
Update splashscreen (according car line)
cardevicelist
Air condition
Auxiliary heating
HUD
ACC
Air suspension
RDK
Interior light
Exterior light
APS
RVC
Wiper
Central lock system
Mirror
Board computer
Clock
Service interval
Central unit master
Compass
Charisma
Lane departure warning
Lange change assist
Braking assist
Front seat memory
Rear seat memory
Hybrid
Side view
carextdevicelist
MFL
VIN
Battery
Oil level gauge
Sliding roof
carfunctionlist
Parking help audio dim 1
Parking help audio dim 2
AM/FM toggle
Oil level gauge extended
carprotocollswitch
Air condition
Auxiliary heating
ACC
Air suspension
RDK
Interior light
Exterior light
APS
Wiper
Central lock system
Board computer
Clock
Service interval
Braking assist
Seat memory
carmenuoperation
ACC
interior light
parking help
AWV
line dep. warning
line change assist.
exterior light
battery
window
air condition
instrument cluster
tires air pressure control
wiper
service interval
seat
central lock
compass
charisma
oil level
VIN
clock
air suspension
head up display
central unit master
hybrid
board book
config
Activate DHCP
Activate fixed IP
Active IP
Show current IP address
language HMI system
language Navi TTS
language SDS
visible languages
diagnose
pml
current value
Reset Level
Reset password
settings
active HDD Nav DB
import multimedia
AMI/AUX
Delay ref sign (ms)
Mic sensibility
Tel settings misc
Microphones
Displays
dtc
changed_dtcs
control
qualified_dtcs
show_single_dtc
untested_dtcs
eepromflags
import MM lock status
Watchdog SH4 status
environment
FOT temperature
Bluetooth device address
WLAN device address
hdd
HDD model
HDD firmware revision
HDD serial number
HDD current temperature
HDD max temperature
HDD power state
smart
storesmart
viewsmart
sparepartnumbers
VW spare part number
spare part num front display
spare part num right display
spare part num left display
irc
trigger
java
Free Runtime Memory
Total Runtime Memory
Garbage Collect
media
Delete Backup Folders
mediabluetooth
SPD record (hex)
mediaplayer
Internal drive info
most
allocationtable
centralregistry
nav
Active PSD
databaseupdate
diagvalues
engineering
gps
map
sensorik
tmc
onoff
activation state
onofftimer
OFF 1 delay (Sec)
OFF 2 delay (Sec)
Standby delay (Min)
Power down delay (Min)
Off2 power down delay (Sec)
BEM shutdown delay (Min)
Transport delay (Sec)
Power down timers state
reset all timer values
reset all timers to test
radio
amfm
Disable Test Mode
Selected Test Mode
Current Station
tunbandinfo
diagtest
singletunertest
stationlist
testmodea
testmodec
testmoded
dab
Detected Device
backgroundscan
componentlist
currentstation
dataservicefilter
dataservicelist
diagtest
ensemblelist
linkingdelay
motdecoder
mutehandling
pilist
sdars
categorylist
currentstation
generalinfo
radiotext
servicestatus
stationlist
versioninfo
tim
messagelist
statusinfo
timerlist
tmcchina
tmcchinastations
tmcchinastatus
tunerannouncment
filter
status
ru
Fan speed
FOT temperature RU
Amplifier temperature RU
FOT temperature RU max
Amplifier temperature RU max
rusirius
mode
sd
attached sd-devices
sd-slot1
Mountpoint
Cardtype
Vendor
Device
Serial number
sd-slot2
Mountpoint
Cardtype
Vendor
Device
Serial number
sds
Last recognized confidence
Language list
serial_if_test
Start serial Test for ETC
static ETC
State of last cycle ETC
Start serial Test for VICS
static VICS
State of last cycle VICS
Start serial Test for IPOD
static IPOD
State of last cycle IPOD
swdl
count down
HW index IT
unexpected resets
current version
user defined mode
ignore region and variant
system
is production mode active
battery voltage (x100mV)
Choose system tone
is system tone active
Serial number
VW system name
cable code info (hex)
connected HUC/BTHS (hex)
PerfLoad Freq. (sec)
CPU
No, Memory, CPU
kind of state line
kind lsd
coredump
emergencyupdate
internal
telephony
signal quality
register state
network type
network identifiers
mic mute state
NAD temp state
NAD temperature
handsfree activity
number of connected devices
BT connection state
GSM power state
btconnecteddevices
telephonyprovider
telephonyscript
telephonystates
trace
internfblock
tracescope
tv
tuner state
selected source
TV norm area
Audio format
Terminal mode
Key panel state
Diversity state
AV 1 norm
AV 2 norm
tvtables
usb
Num of attached devices
Used bus, device address
select USB log. bus
select USB device address
info about device with device address, selected above
version
export version info
export onoff info
Start Script
Train name
versionmu
versionru
versiondu
versionaudio
versiontelephony
versionmost
versionbt
addressbook
copy db to sdcard
copy tef to sdcard
delete db
aevtest
scan for jobs
fakeaudiosettings
functiontest
numlisttest
scripts
slidertest
tabletest
fakeextra
audiomanagment
volumerangers
Entertainment min
Entertainment max
SDS min
SDS max
Navi min
Navi max
Telephone min
Telephone max
Traffic min
Traffic max
audiomisc
Mute pin state
Volume max
Muting reason
inputgainoffset
MW
FM
MUCD
CDC
DAB
DVBT
TV
SDARS
TIM
MU AUX
MU AUX ADAPT
MU DVD
MU FPP
MU BT Device
mme
bluetooth
browser
bths
bths 1
byhs 2
car
carcodingvehicle
steering wheel der.
behicle derivat
configuration line
vehicle model line
cardevicelist
Air condition
Auxiliary heating
HUD
ACC
Air suspension
RDK
Interior light
Exterior light
APS
RVC
Wiper
Central lock system
Mirror
Board computer
Clock
Service interval
Central unit master
Compass
Charisma
Lange change assist
Braking assist
Front seat memory
Rear seat memory
Hybrid
Side view
carextdevicelist
MFL
VIN
Battery
Oil level gauge
Sliding roof
carfunctionlist
AM/FM toggle
carprotocollswitch
Air condition
Auxiliary heating
ACC
Air suspension
RDK
Interior light
Exterior light
APS
Wiper
Central lock system
Board computer
Clock
Service interval
Braking assist
Seat memory
carmenuoperation
ACC
interior light
parking help
AWV
line dep. warning
line change assist.
exterior light
battery
window
air condition
instrument cluster
wiper
service interval
seat
central lock
compass
charisma
oil level
VIN
clock
air suspension
head up display
central unit master
hybrid
board book
config
Activate DHCP
Activate fixed IP
Active IP
language HMI system
language Navi TTS
language SDS
visible languages
diagnose
pml
current value
Reset Level
Reset password
settings
active HDD Nav DB
import multimedia
AMI/AUX
Delay ref sign (ms)
Mic sensibility
Tel settings misc
Microphones
Displays
dtc
changed_dtcs
control
qualified_dtcs
show_single_dtc
untested_dtcs
eepromflags
Watchdog SH4 status
environment
FOT temperature
WLAN device address
hdd
HDD model
HDD serial number
HDD max temperature
HDD power state
smart
storesmart
viewsmart
sparepartnumbers
irc
trigger
java
Free Runtime Memory
Garbage Collect
media
mediabluetooth
SPD record (hex)
mediaplayer
Internal drive info
most
allocationtable
centralregistry
nav
Active PSD
databaseupdate
diagvalues
engineering
gps
map
sensorik
tmc
onoff
activation state
onofftimer
OFF 1 delay (Sec)
OFF 2 delay (Sec)
Standby delay (Min)
radio
amfm
Disable Test Mode
Selected Test Mode
Current Station
tunbandinfo
diagtest
singletunertest
stationlist
testmodea
testmodec
testmoded
dab
Detected Device
backgroundscan
componentlist
currentstation
dataservicefilter
dataservicelist
diagtest
ensemblelist
linkingdelay
motdecoder
mutehandling
pilist
sdars
categorylist
currentstation
generalinfo
radiotext
servicestatus
stationlist
versioninfo
tim
messagelist
statusinfo
timerlist
tmcchina
tmcchinastations
tmcchinastatus
tunerannouncment
filter
status
ru
Fan speed
FOT temperature RU
rusirius
mode
sd
attached sd-devices
sd-slot1
Mountpoint
Cardtype
Vendor
Device
Serial number
sd-slot2
Mountpoint
Cardtype
Vendor
Device
Serial number
sds
Language list
serial_if_test
static ETC
static VICS
static IPOD
swdl
count down
HW index IT
unexpected resets
current version
user defined mode
system
Choose system tone
Serial number
VW system name
CPU
No, Memory, CPU
kind of state line
kind lsd
coredump
emergencyupdate
internal
telephony
signal quality
register state
network type
network identifiers
mic mute state
NAD temp state
NAD temperature
handsfree activity
BT connection state
GSM power state
btconnecteddevices
telephonyprovider
telephonyscript
telephonystates
trace
internfblock
tracescope
tv
tuner state
selected source
TV norm area
Audio format
Terminal mode
Key panel state
Diversity state
AV 1 norm
AV 2 norm
tvtables
usb
select USB log. bus
#54
AudiWorld Expert
If you lose your MMI Seat Setting as seen in the photo above this is the method to recover it:
36: Seat Mem - 07 Coding - Long Coding Helper - change Byte 2, bit 0, to 1
Seat memory will be there however greyed out in MMI
In MMI, Seat Adjustment you are now able to find Driver's seat, you can set Key memory on/off. Set it "on" for both keys separately.
Current coding for seat memory driver (for my vehicle) is: 00581B00000011110000
If that bit is set, set it back to 0, turn off the car and wait ten to fifteen minutes; after a decent amount of time has passed go back in to the module and put back the proper coding. save. clear fault codes and reboot mmi. At this point the option should be enabled and you can program/set your keys to work accordingly.
This is absolutely the dumbest "glitch" I have seen yet in Audi coding. It is up there with BMW's "bug" of coding auto fold mirrors on the F31 and you get a DSC/ABS fault (depending on which ecu revision you have). Very odd and completely inline with peculiar German engineering.
#56
#57
Has anyone found out how to change the speeds that the Automatic Air Suspension changes? It goes from Comfort to Dynamic at highway speed and then at Autobahn speed it goes down one further. In NAR we're never going to get that last drop, but would be nice to change the set point for each to be lower. Can it be done?
#59
AudiWorld Expert
No, however you can lower the vehicle in general and then it will give you the ride height you desire and of course improve the appearance and handling (if you do not go too low.)
I believe you can disable this under reigenlicht or somewhere in that module. I do not recall and never looked to disable it but it may be there because I remember seeing something about it.
#60
