Factory jack placemenet
I opened up my wife's Q7 trunk floor compartment cover and found the jack (with a bag) not attached to anything in the compartment. No wonder I have been hearing noises. How's everyone's jack stored? I seem to have difficulty to find a proper place to secure the factory jack.....
Do you guys have the foam piece in the trunk that holds the tools as seen in this parts diagram for a 2016 Q7? Curious why your 2017 Q7's jack is just sitting loose in the trunk.
Do I see an air compressor and a can of tire sealant in your photo? That might answer the reason why the jack does not have a place in the trunk of the Q7. Audi probably feels that anyone with a flat tire would use the tire sealant and compressor vs. the spare tire and jack.
I was thinking of the same thing. but, the jack was in the truck when I picked up the car from the dealer, and the jack was mentioned in the section "how to change tire"...? There is no spare tire and it has run flats.. so maybe I'll just leave the jack at home.. a bit scary on a road trip without a jack if you know what I mean.
The jack is a no cost option, so I suppose Audi does not expect anyone to use it because if it actually had some value, I am sure they would have charged for it. Without a spare, the jack really has no use on the road, so store it in the garage. You can use it to rotate your tires or if you live in a part of the country where you need snow tires, you can use it to swap out summer and winter wheels/tires. At least it comes in a bag to keep the dust off when stored in the corner of the garage!
So even the 19" tires are run flats as well? I wonder why Audi put a jack in the trunk next to the subwoofer where the BOSE unit is, in the above photo.
I have a wild guess that it has something to do with DOT regulations on new vehicles for sale in the US. Otherwise, there is really no reason why Audi would supply a jack if the car is equipped with run-flat tires and a tire inflator kit. There no place to secure a jack in the trunk.
