SQ7 Virtual Cockpit
Funny, I drifted over and signed up because I'm holding out for the SQ7 release.
The car I'd be swapping for would be my 2014 Cayenne Diesel, which has an analog tach, smack in the middle of the dash. Helpful for my 911 of course, but absolutely useless in my CD with a 4,500 rpm redline and lazy 8 speed auto.
bumping this from the dead. found this on youtube, put the description through google translate. from what it says they were able to turn on the sport mode from the sq7 on a regular q7 VC.
https://www.youtube.com/watch?v=UTuiyRAf1yY
Why do people think that firmware/software is the same around the world?
Provided zero insight on the topic bud. Why are you so hung up on where people are located, I’ve seen a bunch of your posts and they’re all sly remarks on how location isn’t discused in every post. Why do you think that audi has different Q7 clusters depending on the region. Seems more cost effective to have the differences be hardware rather than software.
EDIT: Tried this and got the "normal" SQ7 dials but not the "special" SQ7 VC like we all hope (and not like in the video).
I do not take any responsibility for this info since I haven't tried it but I remebered that there was some talk about this in an UK forum. Managed to track it down but not much talk about it.
BUT it may work only with certain software version
Here I think he ment that it's possible only with version 0300 or higher.
ALSO:
SQ7 screensaver on the dashboard
SQ7 screensaver on the MMI screen
I've found what to change to get the VC to display SQ7 dials
In module 17 go into long coding
Then change vehicle variant to "derivative 2"
Apply changes
Come out of long coding
Choose reset
Then hard reset
Apply changes
Choose reset
Then hard reset
I suspect this is down to firmware as I'm 99% sure if you aren't version 0300 or higher on the Vc cockpit (not the mmi) then it's possible. I'm on 0274 but working on getting the firmware to update it.
ALSO:
17 - Instruments
Coding
Byte 02, Bit 3
Coding
Byte 02, Bit 3
5F - Information Electr. (MMI)
Coding
Byte 18, change the value from 27 to 28
Coding
ALSO:
ALSO:
thanks. I’ll give it a try.
