Winter wheel question
I'm planning on switching out the 21" factory wheels for the winter with a set of 19" wheels. Found these on ECStuning. They look to me like the base wheel for the Q7.
https://www.ecstuning.com/Search/Sit...els/ES2609998/
Can anyone comment if these will fit the 2017 Q7? I've read on these forums that the 19" wheel has the following specs: 19 x 8.5 ET28, 5x112 bolt pattern.
Will an ET32 make a big difference?
Thanks.
Thanks.
Those are actually the 19" stock S7 wheels. There's an 18" version Audi put on the B8 S4 and a 20" version available as the base wheel on the SQ5. The ET32 offset of that S7 wheel version should be ideal for the Q7. Not sure about brake caliper clearance but given how large the front brakes are on an S7, it likely won't be an issue for mounting on the Q7.
carbonLORD
09-17-2004 11:21 AM
