85 UR quattro
Old 08-22-2016, 01:00 AM
  #161
paredding's Avatar
Great hardware store! They look better than the originals...
Old 08-22-2016, 07:27 AM
  #162
team illuminata's Avatar
Thanks. I'm sure they will explode the moment an electron passes through them.
Old 08-30-2016, 08:53 AM
  #163
YAY. Our pictures are back!
We had all our early pictures hosted on some servers that went away. Now we have them hosted more securely and have replaced all the broken links. As a bonus you can also see full size images for this and all our other builds here: https://www.flickr.com/photos/team_illuminata/albums
Old 09-02-2016, 02:24 PM
  #164
Feels like we are very close. Also feels like winter is approaching. Better get cracking.
Started cleaning the fuel injection system. Decided not to dismantle it and just leave well alone.
image by Team Illuminata Motorsport, on Flickr
Air filter housing:
New injectors and seals
Battery!
Old 09-04-2016, 01:57 PM
  #165
On a roll now
Jumped the fuel pump relay to drain some old fuel.
New filter
Had to come up with a way to mount this thingy-me-jig as the mounting tabs were long gone.
Turbo inlet. Tight down there.
and fuel distributor
Our parts shelf is look quite bare now.
Old 09-10-2016, 09:55 AM
  #166
Today's progress. Hopefully not this weekend's progress.
Connected the fuel lines to the warm up regulator.
New fuel filters:
There really isn't much left to do. At least to get it running:
CRANK BOLT
THROTTLE BODY
WIRING ISSUES
SPARK PLUGS
TRANS FLUID
Then once it works:
COOLANT
REAR BRAKE LINE
BLEED BRAKES, CLUTCH
PS STEERING FLUID
WIPERS
BUMPER
HEADLIGHT
INJECTOR BLOWER
TIGHTEN CONTROL ARMS
ADJUST SHIFT LINKAGE
ALIGNMENT
DETAIL
Then we put it away for the winter.
Old 09-21-2016, 09:38 AM
  #167
So, assembly continues as we edge nearer to the momentous day when it drives itself off the hoist, hopefully down the road and not into winter storage.
Got the throttle body cleaned, adjusted and back on.
Then had to fix the inlet air temperature sensor.
Fortunately our 83 has one that looks like it was a replacement once. Ohms check check out too.
A bit of electrical shenanigans and it's in.
Then there was nothing left to do but call my Audi expert, Werner then fire it up!
https://www.youtube.com/attribution_...m-upload_owner
Doesn't idle yet and still needs coolant but we had a little celebration anyway.
Old 09-21-2016, 10:24 AM
  #168
wego0002's Avatar
She is breeeeeeething again :-)))))))))))))))))
Party time!!!!
We don't sound to good on video, :-(((
Congrats my friend.
Ciao
Werner
Old 09-21-2016, 12:31 PM
  #169
Party time!!!!
Congrats my friend.
Ciao
Werner
Thanks for all your help.
I think I sound like James Bond personally
Old 09-30-2016, 11:32 AM
  #170
As this project is sort of wrapping up we started another one we thought you might like. Introducing the Audi UR Quattro Rally Build.
transformation by Team Illuminata Motorsport, on Flickr
Quick Reply: 85 UR quattro
