RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
Time to spend some $$$ - advice please
Old 07-08-2014, 11:09 PM
Nevermindthebollocks's Avatar
Default Time to spend some $$$ - advice please
I have a 2007 B7 RS4 Avant - I am 2nd owner had it for 3 years since 30,000Km - now has 76K on it. I love the car and feel it is worth spending money, as opposed to spitting the dummy and starting over. To date it is been super reliable other than $3K to replace steering motor due a bearing failure and another $1K for a a #2 intake sensor replace and decarb.
1) Brakes coming due - expect this will require discs all round too
2) More recently the suspension has started to rattle/knock a lot over short sharp bumpy surfaces (poor description, like rutted surfaces).
3) The number 2 intake sensor starting to flash the EPC again - my local shop recently replaced the whole intake manifold on account of this - on account it was restricted movement of the flap assemble as opposed to the sensor, there is a kit to fix but requires complete dis-assemble of the inlet manifold)
Any thoughts / recommendations welcome.
Old 07-10-2014, 04:17 PM
Just had the beast up on the lift - front left shock well leaking and starting to show a leak on from right. Rears have little obvious signs of a leak.
Getting some numbers together for Bilstein Shocks and also KW Conversions.
Like the sound of KWs but not sure with my driving I will get any great benefit and do not imagine I would ever be adjusting once set up.
Brakes - can go on for a while longer....phew ! Just get the annoying brake squeal when the pads rub on lips when very hot. May even get away with running another set of pads yet
Old 07-11-2014, 01:11 AM
AudiWorld Expert
Reggie's Avatar
You probably should plan on having the drc serviced. Audi had a recall on them in the USA.
o2se34
2.0T FSI Discussion
05-30-2014 05:24 PM
Newbie123
01-12-2014 03:59 PM
radron26
07-18-2007 10:00 AM
dunkmstr
07-16-2003 06:28 PM
Quick Reply: Time to spend some $$$ - advice please
