S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Test drove a new S4 Sedan 6 speed today. Few questions...
Old 10-03-2004, 03:01 PM
New Member
MTMnet's Avatar
Default Test drove a new S4 Sedan 6 speed today. Few questions...
1. Is the S4 clutch somewhat more difficult to shift smoothly or would I just need to drive it more to get use to it vs. my Allroad 6 speed?
2. Does the S4 Avant drive/feel different from the Sedan?
3. How come the Automatic transmission gets better gas milege?
Thanks,
Mike
Old 10-03-2004, 03:20 PM
Banned
DrGP's Avatar
The clutch is tricky, Avant is hardly any different if at all. Can't explain the mpg difference
Old 10-03-2004, 03:23 PM
donp's Avatar
Tip gets better mileage because if you drive easy it will have you in 4th gear before you know it.
Old 10-03-2004, 04:20 PM
silberpfeil's Avatar
Default After nearly a year, I can either drive smoothly or drive fast...
...but not both. The clutch combined with DBW makes it very tricky.
Old 10-03-2004, 04:34 PM
Senior Member
2953's Avatar
Default Tip's better EPA rating is due to something called "hydrocarbon spiking" that occurs when...
...<font color="003366"> shifting a manual gearbox car.
During low coolant temperature operations, every time the throttle is backed off when the car is shifted, hydrocarbon emissions shoot upward. As engine displacement increases, the deleterious effects of hydrocarbon spiking rises inordinately.
Since cold-start operation is part of the U.S. EPA test larger displacement engines with manual transmissions <i>tend</i> to be penalized by this. As with a planetary gear automatic gearbox, the DSG trans can make each shift without backing off the gas all but eliminating the hydrocarbon spiking issue.
Hope that answers your question.</font>
Old 10-03-2004, 04:50 PM
Junior Member
SelmerMk6's Avatar
Default I always have to laugh when one of my friends test drives my car for the first time. Unless...
they are really experienced manual drivers, it's usually very ugly. I kind of like that, especially when it's my turn to show them how to drive a car with this much power and torque in such a small package. Yes, it takes some time getting used to this car but with a little practice I have found it can be driven smoothly at slow and fast speeds.
Old 10-03-2004, 04:51 PM
New Member
MTMnet's Avatar
Thanks for the info!
Old 10-03-2004, 05:37 PM
JDBlueAudiS4's Avatar
Default well....
The S4 clutch is very easy once you get the hang of it. The avant and sedan feel different on the road but not that much. Both drive exceptionally well. The MPG difference is do to how the car shifts as well as many other things. A Tip is normally in a higher gear then you would be in a manual car
Old 10-03-2004, 05:47 PM
New Member
wahoo99's Avatar
Default Re: After nearly a year, I can either drive smoothly or drive fast...
??? Can you not 'slip' the clutch a little? I'm looking into a '05.5 S4 but haven't test driven the manual. Is the car testy or is the clutch just stiff? After driving my 3 series, the clutch has gotten significantly stiffer over 5 years. I routinely start in 2nd but need to 'slip' the clutch when I'm in rush hour.
I driven several muscle cars and I'm curious to what you mean by slow and smooth or fast?!?
Old 10-03-2004, 06:49 PM
Senior Member
Captain Sheetmetal's Avatar
Default Re: it's just hard to match the RPMs with the speed of the car.
More so than on other cars. At high speed and normally associated high RPMs, a mismatch is much more jarring than at low RPMs.
Quick Reply: Test drove a new S4 Sedan 6 speed today. Few questions...
