2012 s4 - thermostat and check engine light issues
I am on my 3 rd back to the dealer in about a month. First time the car was throwing a add coolant warning and the engine temp was shooting very high. Had the car towed in and they replaced the thermostat and was fine for 3 weeks. Then the check engine / emission control light went on. Took her back in and they replaced a sensor that was logging 20 degrees too high and causing the light to go on. No issues with the car or engine. Brought her back last week and the same light is on again. Car is at the dealer and throwing the same code. They are to work with Audi corporate today.
Any one with similar issues?
This is my first Audi and I love the s4. My factory warranty comes due in August 2015 and as I have Over 10k in warranty repairs in 3.5 yrs and 35k miles I have asked Audi to help w the extended warranty. I am young a car lover but refuse to buy another Audi if this is the amount of **** that goes wrong. 10 k plus (current issue not included) in less than 4 yrs on a new s4.
Thoughts? Are you guys/gals having just as much in issues?
Key issues:
- rear differential replaced
- 2 front b&o speakers replaced
- sirus radio module and attentena
- thermostat replaced
Key issues:
Banned
Sorry for your problems. I am on my 3rd B8 S4. So far I have had my WP crap out and road debris punctured my IC intercooler. Both left me stranded on the side of the road. Other than that, no problems with the cars. I know that doesn't help you, but I think your car may be non typical. If i were you, I would consider trading the car for something else. Otherwise, I would want an extended warranty that had extensive coverage. Audi will sell you one from Fidelity, but it will not be cheap. For the most part, these S4s have been prety reliable for a German built car.
Not sure if I can make you feel better, but as a reference I have a 2010 with 75k miles and I have never skipped a single maintenance schedule from Audi. I change the oil and filter every 5k and trans fluid every 30k. Spark plugs changed every 30k.
Here are the issues and costs for me after warranty expired:
1. Bad Steering Rack: $1800 (Audi)
2. Bad Wheel Bearing: $300 (Replaced myself, very easy.)
4. 65K service $150
5. 75K service $700
6. Uses about 1 quart of oil every 2k miles (known problem with S4)
7. Broken visor clip (Still broke, but a $40 replacement)
8. Suffers from low speed hard shifts occasionally (gonna try the upgraded trans mount)
Audi has always given me 10-15 percent discount on repairs or service every time I have asked.
Not bad in my opinion for this car or maybe I have been lucky. As noted below I also have been running mods for about 30k miles, which is why I do certain maintenance more often.
4. 65K service $150
5. 75K service $700
Banned
4. 65K service $150
5. 75K service $700
4. 65K service $150
5. 75K service $700
UPDATE - Sorry for the delayed response. The dealer along with Audi resolved the issue after having one of their techs from Germany come in to the dealer. Basically they needed to reset the Cooling software after the thermostat replacement. For whatever reason it was creating a false alarm after a few weeks and would throw the same check engine light on. I have had it back for a while now and its been good.
Audi also offered to split the 4 yr platinum extended warranty with me so that gives me 4 yrs / 48 k now. So feel much better about keeping the car.
$1200 thermostat replacement
I can feel your cooling issues pain! Just got done paying $1,200 for a new thermostat installation at the dealer. Car is an '11 S4 with 60K miles and was part of the thermostat recall back in 2011. So, this is the second t-stat its had so far. I hope this isn't a trend...
I lurk on R8 talk (dreaming...) and it sounds like a number of folks have had leaking magnetic ride shocks to the tune of $4K. So, it can always be worse. Although, come to think of it, I would rather pay $4K for new shocks on an R8 than $1.2K for an new t-stat on an S4!!!!
