S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Recommended tire pressure
Old 03-10-2014, 07:41 PM
incognitoS4's Avatar
Default Recommended tire pressure
Hi. I am just curious what the recommended tire pressure for our cars is, I have the 19" rims and the Contis the car came with. The door sticker has 41/41 while the manual has 39/33. Thanks.
Old 03-10-2014, 08:10 PM
Fabio Corsi's Avatar
I go by the owner's manual: 39/33
Much better and smooth driving comparing to 41/41. That's just too much in my opinion
Old 03-10-2014, 08:53 PM
Joe85STi's Avatar
41/41 is for a fully loaded car. So unless you usually drive around with 3-4 passengers, you want to keep the pressures lower.
Old 03-11-2014, 03:09 AM
uberwgn's Avatar
Incognito, if you crack open the Owner's Manual and look towards at the rear of the book, you'll find comprehensive inflation info for you car. It'll call out the various wheel diameters and recommended pressures for Normal load vs. MAX load.
Sadly, in the USA, the B pillar sticker shows only MAX load
Old 03-11-2014, 03:21 AM
RickFLS4's Avatar
As others have stated 41 is for Max load. If you fill to 41 without Max load and drive around like that all the time, the center section of the tire treads will wear out too soon because the tires are over-inflated. I go with (about) 39/36 and use nitro fill so typically don't need to add anything between tire rotations (but still check at least once / month).
Old 03-11-2014, 09:58 AM
Guest
GUEST123's Avatar
I've used 41lbs F&R for over 3 years and never had any unusual tire wear on either the summer or winter tires. It does make for a somewhat more firm ride, but it hasn't been unduly harsh. So far, the tread wear has been quite even. I also check pressures regularly and have kept the car in alignment. I have nitrogen in my new summer Michelin PSS tires, and will eventually refill the snows with it too.
Old 03-11-2014, 11:21 AM
4wdFan's Avatar
I can confirm this. I overinflated tires on my S4 and the center wore out while the sides still had a fair amount of life left.
Slides
43
11-11-2019 06:54 AM
USe-car
TT (Mk3) Discussion
23
02-05-2019 03:11 AM
18A5SB
19
08-15-2018 09:46 AM
dudley07726
A6 (C7 Platform) Discussion
18
09-12-2016 12:17 PM
gk1
Q5/SQ5 MKI (8R) Discussion
10-18-2013 02:25 PM
Quick Reply: Recommended tire pressure
