S adaptativ damping suspension?
#11
This version of the adjustable suspension arguably degrades performance but improves comfort.
#12
#13
A suspension with soft compromised springs is the ideal performance setup? Based on current information, this adjustable suspension is similar to that of the B8 S4, which was inferior to the fixed suspension for spirited driving. Unfortunately, this is not a suspension with magnetorheological dampers.
#14
This is not the comfort adaptive suspension, and it is not the B8 setup.
And you have a different spring rate with th adaptive dampers because this then allows the dampers to do their work.
The S Sport package with 18" wheels and Dynamic steering is your ideal performance setup.
#15
Plenty of current information out there to clarify the systems are very different. Read up on the new centralised chassis control system used on the B9 platform, too. An S3 uses mag dampers. Audi tend to use them with Haldex based quattro systems, the R8 uses them too.
US already has the "soft" version of adaptive suspension - should be possible to drive back to back with the standard passive suspension and see if you find the spring/damper rates feel unbalanced in either Comfort or Dynamic on the adaptive system vs the passive.
BMW's current M3/M4 use previous generation ZF Sachs CDC dampers on their Adaptive Drive option. Lots of discussion on BMW forums if interested in how owners view it vs passive.
Main reason to choose the passive system is budget, or because you may want to modify suspensions characteristics. Such as lowering the car, or using much heavier wheels/tyres. If the latter, it is frustrating to have the Sport differential tied to the adaptive dampers. Not just because there is some added cost (USA seems very slow to release any prices) that will be wasted, but because ripping out the CDC system and replacing it with coilovers is likely to cause problems within the chassis control system that will require some coding hacks to overcome.
#16
You'll just have to trust me.
The base configuration is fixed dampers, with 18" wheels.
Those two are more likely the "ideal" configurations as tuned by Audi, although I doubt mixing and matching is going to be a disaster.
#17
Every pre-production S4 that Audi built was fitted with S Sport adaptive suspension (plus Dynamic steering and Sport differential)... and 19" wheels.
#18
I thought the bigger the wheels, the harder/better it was for cornering, braking, etc.? It certainly all depends on the tires themselves, though. The S4 B9 comes with 19s, though I would have loved 20s (like my Porsche's ^^). You lose a little bit in comfort with big wheels, so I guess 19s should still look great and perform well enough. I'd only go for 18s on a winter wheels set.
#19
Or as you said, using as your winter wheel where it will add some protection against damaged roads.
The new S5 Sportback shown in Paris was on 20" wheels. The tyres were Continental SportContacts (and not Hankooks!!), but series 3 which is pretty old. What was interesting was that they were 265/30 R20, which suggests the new 20" rotor design is a 9" wide wheel. This is relevant because unlike the B8 platform, the S4 and S5 share offsets and have similar clearance geometry.
Many of the wheels are shared, and the unique versions are interchangeable. The A5/S5 has more 19" wheel options than the A4/S4, and all 19" wheels are fitted with 255/35 tyres, rather than 245/35 on the A4/S4.
B9 S5 Sportback with 20" wheels
#20
The S4 Sedan and S5 Coupé do not share offsets. S5 is ET32 vs ET40 for the S4 sedan. And yes, the width of the tire is also increased on the S5 to 255 compared to 245 on the S4.
And still, as I said before, the 18" tire is the best performance option, regardless of the suspension.
