Cel came to visit..had 9 codes..please take a look..
So a little background. Car has had a misfire problem at idle for some time now, change a TON of stuff, but never 02s because i wasn't getting any codes for them.Could 02's cause the msifiring at idle? Here they are, please let me know what you think if you have time. I am unsure what 02s need replaced. Thanks guys..
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
P0421 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
16538 - Oxygen (Lambda) Sensor B2 S1: No Activity
P0154 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
16689 - Cylinder 5: Misfire Detected
P0305 - 35-00 - -
P0421 - 35-00 - -
P0300 - 35-00 - -
P0304 - 35-00 - -
P0303 - 35-00 - -
P0302 - 35-00 - -
P0305 - 35-00 - -
Replaced plugs, swapped coilpacks, upgraded coolant temp sensor,swapped ignition coils..and more..
unpluged maf..etc..Are the front 02s the primary? Are all 4 of the 02s the same im assuming? Car has 150k on it, so it wouldn't surprise me if they were bad.
And one more thing, Are they a pain to install?
GuyWithanAudi
09-23-2011 07:26 AM
