Clunk, Clunk, Coast, No go
#13
drivers side axle totally disconnected <more>
All the bolts are there... not stripped and nothing broken. I'm going to take a guess and say the shop forgot to tighten them during the stage 3 install.
-Matt
-Matt
#14
Yep. That's what I thought. Once they're tightened up you should be fine.
<ul><li><a href="https://forums.audiworld.com/s4/msgs/2275192.phtml">https://forums.audiworld.com/s4/msgs/2275192.phtml</a</li></ul>
#16
You can't accurately torque them because you'd have to use extensions and such...
As tight as you can get them with a 3/8" drive ratchet is fine. Hold on to the wheel with one hand and tighten with the other.
I used to use my electric impact with a 30" extension on em but ended up checking them with the ratchet anyhow, so I just use the ratchet now.
#17
I realize this is an ancient thread but I can absolutely confirm that with a broken axle/joint, the car won't move but the speedo will. I bought a 2001 Allroad at an auction. The left front inner joint was broken as was the rear lower control arm in that area. The vehicle wouldn't move but the speedo moved when in gear (grinds badly if put in Park while speedo is registering). I replaced the control arm, front lower arm for good measure, and the axle. Vehicle now moves just fine.
anthony sanders
04-28-2014 04:27 AM
Roger @ CA
Mid Atlantic Discussion
14
12-12-2006 12:37 PM
GrandPaJohn
12-02-2003 04:02 PM
