!!! DTC code help !!! Please!!!
Old 08-08-2002, 07:19 PM
New Member
NY S4 driver's Avatar
Default !!! DTC code help !!! Please!!!
Just got these fault codes on the engine controller:
16490 - Manifold Pressure Sensor (G71/F96): Implausable Signal 35-10 - - - Intermittent (Manifold Abs.Pressure or Bar.Pressure Range/Performance)
18058- Data Bus Powertrain Missing message fr.instrument panel ECU
17973- Idle Speed Control Throttle Position lower limit not attained
17987- Idle Speed Contr.Throttle Pos. Adaptation not started
16622- Turbocharger Boost Sensor (A) Circ High Input
18057- Data Bus Powertrain Missing message from ABS Control Module
16497- System Voltage High Voltage
16502- Engine Coolant Temp.Circ High Input
18010- Power Supply (B+) Terminal 30 Low Voltage
Can anyone explain these any better? Are any of these something serious? Can the car still be driven, with or without a chip?
TIA
Old 08-08-2002, 07:25 PM
M3iRiSH's Avatar
Default Sound like a sending unit is shorting...
I can't tell if it would be drivable or not.
Old 08-08-2002, 07:27 PM
New Member
What is the sending unit?
Old 08-08-2002, 07:37 PM
M3iRiSH's Avatar
One of the componets (i.e. 16502) that is sending out a signal to or from the ECU...
NoFHoes's Avatar
Double check all your wiring in the engine bay and ecu area. what the heck eh?
Old 08-08-2002, 07:40 PM
New Member
Oh....
Old 08-11-2002, 06:37 AM
New Member
ArrayMFC's Avatar
Default Friend had same problem. An electrical harness had frayed
I'll find out where and let you know.
Old 08-11-2002, 09:26 PM
New Member
Please do...
thewatcher101
11-12-2007 07:18 AM
geefunck88
07-11-2007 02:30 PM
Eric NY
02-07-2007 10:53 AM
alipor
VAG-COM Discussion
08-09-2005 09:43 AM
stealth
Misc. Models Discussion
01-30-2001 08:48 AM
Quick Reply: !!! DTC code help !!! Please!!!
