Dyno results from EPL. DAP will be posting ECUx data later on
Old 05-14-2006, 06:42 AM
  #31
Former Vendor
Tony@EPL's Avatar
Default 12.9 is the correct hp@50 for an s4...(more detail in side)
We (DAP and I) had many questions about this awhile back. We contacted mustang and this is their responce.
Dave,
> The weight entered into the software can have an effect on the HP/Torque numbers, sometimes 10% to 15% although it is usually less than 5% variation. The weight in the look-up table should be used for purposes of repeatability during return visits by the same vehicle, but, if you want accurate 1/4 mile sprint times you should use the actual vehicle weight with driver weight added. FYI, the weights in the look-up table assumes a full tank of gas and driver of 200Lbs, rounded to the nearest 25Lbs. The HP @ 50mph for an Audi S4, 2.7L is 12.9.
> Regards,
> Mustang Dynamometer
> 2300 Pinnacle Parkway
> Twinsburg, OH 44087
> www.mustangdyne.com
Old 05-14-2006, 07:17 AM
  #32
SmokinS4™'s Avatar
I don't know...same number for everyone....even though MarkP was completely stripped (no furniture)
Old 05-14-2006, 07:19 AM
  #33
SmokinS4™'s Avatar
Default Also note that it doesn't matter....but I can compare my car to my car on this dyno until a variable
changes, then it makes all historic data junk.
Old 05-14-2006, 07:20 AM
  #34
SmokinS4™'s Avatar
Thank again for Sponsoring the day Tony! Good time was had by all =)
Old 05-14-2006, 07:21 AM
  #35
Audiworld Sponsor
DAP@EPL's Avatar
Default Mid 11s from torque peak on seems to be optimal for the 2.7T on pump gas.
Enough fuel to provide sufficient cooling, keep timing high and stay safe without being too rich and choking the motor.
-Dave Pramanik
Old 05-14-2006, 07:39 AM
  #36
JasonS4+Festicle's Avatar
Default I agree, was just curious. Dyno #'s really don't mean anything when trying to compare dyno to....
dyno.
Depending how the dyno is set-up you get very different #'s all over the country.
But, yeah, your car on the same dyno set-up in the same way from day to day is accurate. (And different cars on the same dyno the same day are also valid comparisons)....
Old 05-14-2006, 08:23 AM
  #37
skidmark's Avatar
Default Sorry, here is link of his which agrees with your post.
<ul><li><a href="https://forums.audiworld.com/s4/msgs/2097444.phtml">https://forums.audiworld.com/s4/msgs/2097444.phtml</a</li></ul>
Old 05-15-2006, 09:30 AM
  #38
SmokinS4™'s Avatar
Default ECUx data
3.5second FATS tims<ul><li><a href="http://65.182.219.254/smokin_s4/DynoatEPL5-13/smokinS4.htm">http://65.182.219.254/smokin_s4/DynoatEPL5-13/smokinS4.htm</a</li></ul>
Old 05-15-2006, 09:41 AM
  #39
SmokinS4™'s Avatar
Default Compare to older data (with AMS software)
<ul><li><a href="http://www.pramanik.net/AW/SmokinS4/Matt_AMS.htm">http://www.pramanik.net/AW/SmokinS4/Matt_AMS.htm</a</li></ul>
Roger @ CA
Mid Atlantic Discussion
12
11-27-2007 11:45 AM
zeus1
07-20-2006 08:12 AM
Audi Skate Sn0w
05-03-2006 01:41 PM
LoSz
04-27-2005 05:10 PM
zeus1
01-17-2004 09:59 AM
Quick Reply: Dyno results from EPL. DAP will be posting ECUx data later on
