Which heads, etc., with the aluminium 3.0L block? 2.4L, 2.8L, 2.7L or RS4 ???
Old 10-17-2006, 04:47 PM
  #251
FixedWing's Avatar
Default I believe the journals are identical in the 2.7L, 2.8L and 3.0L
The journals in the RS4 are slightly larger. The fact that they beefed up the crank for just that one specific application tells you something..
Stephen
Old 10-17-2006, 04:49 PM
  #252
Elder Member
S4mig@PEB tuning's Avatar
Well now someone really needs to see if the 3.0 crank will drop in. That would be ideal IMHO.
Old 10-17-2006, 04:55 PM
  #253
FixedWing's Avatar
I believe it will drop in. I don't believe it will turn. There isn't enough clearance.
Old 10-17-2006, 05:03 PM
  #254
Elder Member
Blocks can be internally clearanced but to what exent won't be known till someone attempts it.
Old 10-17-2006, 05:04 PM
  #255
FixedWing's Avatar
I've been told that it is too much with the connecting rods on.
Old 10-17-2006, 05:06 PM
  #256
FixedWing's Avatar
Default Where did you get your figure for the stroke of the 3.0L ???
It's wrong. It should be 92.8 mm/3.65 in.
154 / 92.8 = 1.66 ratio.
That makes more sense.
Bore is supposed to be 82.5 mm.
Stephen<ul><li><a href="https://www.audiworld.com/model/a4/05/05A4Sedan_TechSpecs.pdf">https://www.audiworld.com/model/a4/05/05A4Sedan_TechSpecs.pdf</a</li></ul>
Old 10-17-2006, 05:08 PM
  #257
Elder Member
Source?
  #258
AudiWorld Expert
Captain Matt, I be's Avatar
Default I just dont think 8000rpm is really pushing things that hard provided quality components are used
high end conrods, stiff valvesprings, high end fasteners and balanced rotating assembly should keep things together just fine.
plenty of japanese make turbo cars pushing 9k and higher. i believe tony@epl turns 8100 on his 1.8T with valvesprings only as well.
Old 10-17-2006, 05:11 PM
  #259
FixedWing's Avatar
A little birdie told me. :-)
Old 10-17-2006, 05:15 PM
  #260
FixedWing's Avatar
Default What is the mean piston speed at 8000 RPM?
(92.8 / 1000) * 2 * (8000 / 60) = 24.8 m/s
(or 4870 ft/min)
That's really pushing it!
No doubt you can do it but how often will you need to rebuild? It is also hell on the piston rings.
Stephen
newport 4.2
4.2 V8 Discussion
01-02-2009 02:28 PM
RI A6
RS4 (B7 Platform) Discussion
42
10-06-2007 01:19 AM
JogJog
09-02-2007 07:31 PM
FixedWing
67
10-07-2005 04:44 AM
Quick Reply: Which heads, etc., with the aluminium 3.0L block? 2.4L, 2.8L, 2.7L or RS4 ???
