Heater core - Ok to drive if broken?
Old 05-21-2009, 10:08 AM
New Member
Vegas-S4's Avatar
Default Heater core - Ok to drive if broken?
I think my heater core is out. Is there any problem with driving the car with a bad heater core? I live in Las Vegas and its summer, so I don't need heat right now.
I tried flushing and bleeding it, but no luck.
Old 05-21-2009, 11:20 AM
donromani's Avatar
broken how? Is it leaking or just fried? Either way I think you're fine to drive it as long as you don't run the heater.
Old 05-21-2009, 12:09 PM
New Member
Vegas-S4's Avatar
It is fried.
Old 05-22-2009, 03:57 AM
r1de23's Avatar
are you not getting any heat inside the car? i wouldnt think it would matter, unless coolant is leaking..
Old 05-28-2009, 05:28 PM
dr13's Avatar
I've had cars where the heater cores started leaking.If thats the case you can bypass it by taking the hoses off and connecting them together.not sure if will work on the s4,but it has worked for me in the past.at least untill you can fix it correctly
Old 05-29-2009, 10:15 AM
jumpnofear's Avatar
Is it leaking? If so I am not sure how you can run AC w/o picking up some of the mist. I could taste it when I licked my lips while driving my car w/ a leaking heater core. I wonder if it effects the ability of the cooling system to be ender full pressure as well - I always thought that was part of the reason for bypassing - per the previous response. It is such a pain they should make them out of something indestructible imo. When the AC evaporator went on the S4 I had them replace the heater core while in there just to never have to go through it again.
Old 05-29-2009, 12:39 PM
dr13's Avatar
Thats a good question,I never had any problems with the pressure increase affecting the cooling system.I guess it could be problem if any of the hoses or seals were already weak.But I have only done this as temp fix to a daily driver and on a weekender that was setup more towards light to light racing.
gogu
20
05-03-2006 05:41 PM
talltorontoguy
13
03-01-2005 05:48 PM
moses
06-20-2004 07:03 AM
thermonuclear
10
11-08-2002 11:58 AM
Paul Graham ("C46")
03-08-2002 01:24 PM
Quick Reply: Heater core - Ok to drive if broken?
