Loud knock in the rear when hitting bumps on highway...????
Cannot figure out whats making the noise, it only happends at fast speeds over larger bumps in the road, some times i even get multiple knocks, if im going fast.
Could it be the rear diff. mount? a rear suspension component?
sounds like its coming from the rear of the passenger side.
I can feel the bang if my arm is on the armrest....
TIA
TIA
Maybe, dead body in the trunk...............lol
Had the same issue a couple years ago; replaced the suspension and control arms and it went away. Never had it fully diagnosed as I had ordered the parts before it started happening and replaced shortly thereafter...
-Chris
-Chris
could be a blown shock, bad control arms...
loose suspension bolt, broken sway bar endlink, loose subframe bolt....
Start checking all of it...no good way to e-diagnose this one...you're in the best position to figure it out.
aftermarket exhaust??? I had exact same symptoms once.
my suspension would flex and the exhaust was tapping against the rear diff, i could feel it in the armrest...of course this was right after i had some CPO warranty work done, dealer fixed it no problem.
Crawl underneath and move the exhaust by hand when its cold, see if it hits anywhere.
Otherwise, check all suspension components.
Afroney
02-20-2003 08:22 PM
Gop-Dogg
05-15-2001 02:29 PM
