More bull**** w/ my driveshaft, need AWers wisdom to help me
Old 03-10-2008, 11:02 AM
  #21
Cooper993's Avatar
Any reason why you went with this vendor vs. another that is cheaper?
Old 03-10-2008, 11:22 AM
  #22
Jsmooth65's Avatar
Default Mostly time. The others weren't going to have it to me in a timely manner,
Somebody else used this vendor before and was satisfied, so I know its not shady. The guy on the phone was very knowledgable as well and I'm pretty sure he was the guy that was putting it together. Raxles said they had no way of balancing the driveshaft either. And the $535 they quoted me was including shipping, which will get the thing to me in 3 days.
Old 03-11-2008, 07:22 AM
  #23
Jsmooth65's Avatar
Default I just called them, and they built and shipped it out the same day I called them
Should be here in 3 days. I will take pictures of the product when it gets here.
Old 03-18-2008, 08:48 AM
  #24
Jsmooth65's Avatar
Default Pics inside
Here is a pic of my bad front CV from above the cats. You could literally shake it, it was SOO loose. The grease was so dehydrated, it was almost like putty.
<img src="http://i29.photobucket.com/albums/c274/Jsmooth65/badCV.jpg">
Here is a pic of the new driveshaft from PowerTrain industries.
<img src="http://i29.photobucket.com/albums/c274/Jsmooth65/newdriveshaft.jpg">
Installed her up and the rattling/clanking sounds are no more!
Old 03-18-2008, 09:17 AM
  #25
Cooper993's Avatar
So that CV isn't a replaceable item? You have to change out the whole shaft? My rear CV is shot.
Old 03-18-2008, 09:55 AM
  #26
Jsmooth65's Avatar
Default No, you could replace the CV alone if you wanted. Its about a $100 part
I just figured since I was going to have the driveshaft out, I would replace the support bearing (which was much softer and weaker than the new one) and the rear CV as well, since it could go bad later. Totalling the parts, the price was inching up towards the same price as a rebuilt shaft, so I paid a little extra, but got the whole unit and saved some time and sweat.
Its the same principle as the CV halfshafts. You can replace the boot for $30 or so, replace the outer CV with a new one for about $150, or just buy a complete rebuilt unit for $90.
Old 03-21-2008, 06:02 AM
  #27
Hibiscus Red S4's Avatar
yes there is
Old 02-15-2010, 08:04 AM
  #28
Flyboy's Avatar
Originally Posted by davenew
<img src="http://dave-new.com/S4/driveshaft/shaft/propeller_shaft.JPG">
<img src="http://dave-new.com/S4/driveshaft/shaft/DSCN2050.JPG">
Here's mcmaster-carr driveshaft bolts. Much cheaper than oem and same grade, etc.
<img src="http://dave-new.com/S4/driveshaft_bolts.jpg">
If you find the picture of my driveshaft cv joint gaskets, it's an old part number. Check with the dealer for a revised pn that's also much cheaper. I paid $20+/ea while the revised pn is only $7/ea.
FYI, I believe the driveshaft has a different pn for tiptronics.<ul><li><a href="http://dave-new.com/S4/driveshaft/">here's all of my driveshaft pictures</a></li></ul>
New part number is: 8D0 407 309A
Old 02-15-2010, 09:37 AM
  #29
AUDI_S4_ATL's Avatar
I had that knocking during acceleration and I took off the cv at the rear differential cleaned the bearings and all the bad grease and just repacked it using commercial grade grease and the noise stopped. The only reason I didnt change the cv was because there was only normal wear on the bearing cages and no physical damage to the ***** and they were still very tight. Just throwing that out there for people who would want to try this before spending a bunch of money.
MXZ1983
02-21-2011 08:01 AM
kenyel
09-20-2010 04:39 AM
VAP
24
10-14-2005 06:44 PM
Shavedquattro
04-07-2003 06:30 PM
Quick Reply: More bull**** w/ my driveshaft, need AWers wisdom to help me
