preliminary 2.8 cam info....some slightly interesting stuff
Old 06-07-2004, 01:33 PM
Banned
Mike@VAST's Avatar
Default preliminary 2.8 cam info....some slightly interesting stuff
Nick G and I measured that the 2.8 USA cams have about 0.043" more lift than stock and the 2.8 Euro/RS4 cams have about 0.030" more lift than stock...
so, I put the USA cams in my car and checked the airflow out...19-20 psi peak tapering to whatever k03's do on my car...say, maybe slightly less than 1 bar.
i have no idea if the duration is the same. i bet it is, but who knows. the car runs fine, though, there is a hiccup from 3800-4200 rpm now.
anyway, it LOOKS like I have a slight gain from 5600-5700 up to redline where the airflow doesn't taper as bad. Regardless, I'm on POS original k03's and can't believe I went through all of this
If I figure anything else out, I'll post. Docslow mini-person and I are supposed to meet up and go over things since he and I pretty much have the same car but he is on stock cams.
Mike
Old 06-07-2004, 01:35 PM
Elder Member
PSmalls::DoggieStyle's Avatar
no comment.
Old 06-07-2004, 01:38 PM
Banned
Mike@VAST's Avatar
Default my only comment...probably doesn't do any good on stock turbos :p
what a PITA!!!!!! just for that. lol
Old 06-07-2004, 01:39 PM
Elder Member
Default Time for us to put RS4 cams in my car and do a comparison :)
Honestly, from looking at your logs, I don't see any difference whatsoever in the shape of the airflow curve up high.
Old 06-07-2004, 01:40 PM
Funkweasel's Avatar
Default Well at least you got the tb done right? I fricking told you to do the k16s while you
were there. ;ppp
Old 06-07-2004, 01:41 PM
Elder Member
Default Maybe if a special *someone* would send us some k16's, we'd put them on his car....
timing belt?
Old 06-07-2004, 01:42 PM
Banned
Mike@VAST's Avatar
Default i think i'll be hoping that my car lasts!
Elder Member
Please delete this post before Troy and I vomit.
Old 06-07-2004, 01:43 PM
Banned
Mike@VAST's Avatar
Default well, i don't think it went in a negative direction or flatlined as bad. oh well! we can do whatever
but i have to get ready to leave for CO
Old 06-07-2004, 01:44 PM
Elder Member
Default I should probably send you my log to compare, eh?
YGM in a few, porky
Quick Reply: preliminary 2.8 cam info....some slightly interesting stuff
