how do you get the driver's side motor mount out? the a/c hard lines are in the way :(
Old 08-13-2008, 07:36 AM
Junior Member
lulz's Avatar
Default how do you get the driver's side motor mount out? the a/c hard lines are in the way :(
got the passenger side out, but now i cant wiggle the driver's side out because its blocked. arg
Old 08-13-2008, 08:02 AM
Illusive90S's Avatar
Default Remove oil filter, remove tension from the accessory belt and remove that. Then...
remove the three bolts on the a/c compressor(?). That will give you enough room to remove the inlet pipe and get to the motor mount. I just did mine Sunday night; not something I'd like to do again.
Old 08-13-2008, 08:26 AM
Junior Member
lulz's Avatar
Default i got the inlet pipe out without dropping the compressor
too bad i'm still going to have to drop it because i dont have enough room to wiggle out the motor mount. ARG
Old 08-13-2008, 08:38 AM
Default If its already loose, remove the bracket that attaches to the subframe?
you may only have to loosen it some. I can't imagine how you got the inlet pipe off without taking out the compressor, it only took a few minutes to do and was much easier than wrestling the inlet pipe out with it in.
CRAZY_RUSSIAN
12v V6 Discussion
12-17-2008 03:58 PM
Mr.Jai
10-29-2007 09:29 AM
Allroady DungBeetle
06-11-2006 05:32 AM
TwentyValveB5+S4
10-15-2005 01:35 PM
AudiSport4000
02-25-2004 05:06 PM
Quick Reply: how do you get the driver's side motor mount out? the a/c hard lines are in the way :(
