Rear Wheel Bearing replacement write-up
Old 02-16-2006, 02:42 PM
  #11
NoFHoes's Avatar
Nice!! Aw shucks that it is not really a DIY unless you have that press thing.
  #12
Fairfax 4.0T's Avatar
Default Very Nice: Question regarding removal of bearing race from hub.
So you just wedged a chisel between the hub and the bearing race stuck on the hub to remove it? Were you worried about damaging the hub with the chisel? It looks a tiny bit beat up.
When I had this issue, I used a dremmel. Any comments or thoughts on using the dremmel? See the link.<ul><li><a href="https://forums.audiworld.com/midatlantic/threads/10964.phtml#115972">Remove race from bearing</a></li></ul>
Old 02-16-2006, 02:45 PM
  #13
AudiWorld Expert
Milpitas2.7T's Avatar
Default I think I paid less but $80 harbor freight, I have the same one. Needed it for my
DSM and my Pcar when doing suspension work
Old 02-16-2006, 02:49 PM
  #14
SilverB's Avatar
Default Nice job!
I go through those things like printer paper. I do not understand why Audi's chew these up.
Old 02-16-2006, 02:59 PM
  #15
S4andTLS's Avatar
Very informative. :P I applied grease to the outer surface of bearing for future removel.
Old 02-16-2006, 03:02 PM
  #16
Senior Member
SAC-CA-GTI's Avatar
Default Also note that the bearing is rounded on the inside of the part that goes against the hub, also
it is easier to just press the hub out, THEN press the whole bearing out so you don't have to pound on the part of the bearing stuck on the hub. The correct torque for the front is 141lb plus 180. Great writeup! And I was sent an orange bearing for my front from PureMS, but ended up getting one from the dealer as I wanted the swiss bearing, not a canadian which the oranges are. Not sure if it really makes a difference or not.
Old 02-16-2006, 03:12 PM
  #17
Stätus Josh
Guest
Posts: n/a
hero!
Old 02-16-2006, 03:18 PM
  #18
Hogothorpe's Avatar
Canadian &gt; Swiss
Old 02-16-2006, 03:36 PM
  #19
reefer_bob's Avatar
Default Outstanding writeup! Thank you.
You make me want to go buy a press.
Old 02-16-2006, 03:41 PM
  #20
AudiS4inCT's Avatar
Excellent write-up. I'll definitely be saving it for when the rumbling comes.
Quick Reply: Rear Wheel Bearing replacement write-up
