Requested boost maxing out MAP sensor
<center><img src="http://s4.thefarnys.com/Logs/2008-3-11-ASP_with_SDR_and_ERs__first_run_files/2008-3-11-ASP_vs_AWE-New_vs_AWE-Old_10889_image001.png"></center><p>
Hi All,
Trying to figure out some overboosting I'm seeing. My gauge says 24.5 psi, you can see in the pic I'm maxing out not just on actual but requested also.
Question: Intuitively I could see a torn wastegate line causing overboosting i.e. ACTUAL boost being over, but would the same cause ever lead to REQUESTED being that high or is this purely software asking for that much in the first place? Is there anything other than software that would ever cause REQUESTED boost to be this high?
(I recently changed to ASP fueling)
TIA,
Per
Hi All,
TIA,
Per
i did last night and couldn't find anything. one thing still left to do is..
..pressurize the wastegate line off of the n75 with 6-8 psi to see if wastegates open, etc.
but i'm truly confused: why would REQUESTED ever be this high?
top of MAP sensor is 2.54 bar (22.34 psi) Your log looks slightly higher than AH10's ASP3 (see link)
Your SW is asking for that much boost.
Bruce<ul><li><a href="https://forums.audiworld.com/s4/msgs/2783600.phtml">click!</a></li></ul>
thanks. yes, i do know i'm going over MAP sensor limit. anthony also runs ASP, and
...he's been looking at this also. I have same file as Chinh (drgolfnut) who has exact same hardware as I. But apparently a 'minor' revision was made to it. <a href="https://forums.audiworld.com/s4/msgs/2741940.phtml">Chinh's logs here</a>.
I just want to know definitively if there are inputs to the ECU that would cause it to request that much or is it plain and simply that the ECU was programmed to ask for that much regardless of anything else?
Different cars react to the same file differently. You can program boost to be one way on car A and
then put it on car B, which will request more/less boost. That looks to be the case here. Your car is most likely doing exactly as the programming is asking it to do. Just because the MAP sensor limit is stopping requested boost from being visible over that point does not mean the software is not in fact asking for the 24.5 PSI you're seeing.
thanks. yeah, i'm sure it's asking for what i'm seeing on the gauge since
requested/actual is very close everywhere else.
so, i never thought what you state to be the case: i thought if it's the same software, it'd ask for the same thing.
i guess i'll get ASP to get me a revised file and see if it makes a difference.
thanks,
Per
thanks,
Per
