So, after a weekend in a Q7, i want the comfort blinker...how is the install?
#27
I found this write up in the A6 forum... the guy removed the radio to get access to the
wiring harness for the hazard switch?
Is that how you gained access?<ul><li><a href="https://forums.audiworld.com/a6/msgs/594512.phtml">https://forums.audiworld.com/a6/msgs/594512.phtml</a</li></ul>
#28
no way.
on our car all you have to do is carefully pull the trim right off the hazard surround. there are a half dozen metal clips held onto the trim with thin plastic tabs. they may snap but can easily be epoxied right back in place. then you can pull the hazard relay unit out and access all the wires needed to install the unit. it will fit behind the relay too.
AWOT extra 23052
Florida Discussion
05-02-2004 05:54 AM
Crapple0
NorCal Discussion
01-24-2003 08:48 AM
pat33
09-06-2002 03:54 PM
skabaru
01-16-2002 04:18 AM
