Stage 3+ dyno from KTR
Old 07-08-2004, 04:06 PM
Senior Member
J.Moss@TorqueFactory's Avatar
Default Stage 3+ dyno from KTR
<center><img src="http://pictureposter.audiworld.com/15175/ktr_its_rsk04.jpg"></center><p>Hi Everyone,
Here is a dyno plot from a car that was just completed at KTR.
Please, let's not start a this dyno sucks post. That is why I had them compare a stock S4, so we could all see the difference.
Mods:
Big-Port heads
RS4 Cams
RS4 intake manifold
RS4 Throttle Body
RS4 IC's and up-pipes
HSSSK045's from ITS
AWE MAF w/straightener and Software with sauce from Moss
LaBree DP's (Tantrumwerks.com)
BTW the plots are both on 93 octane
The sauce was off the shelf sauce with a Piggie MBC set up to only limit the initial overshoot. This is a problem on the bigger turbos if the sauce is not tuned for them.
Everyone was pretty impressed with the power it put out on pump fuel...
Old 07-08-2004, 04:08 PM
~DonQPremiumTequila~'s Avatar
Did Franz fax that copy over to you!!
Old 07-08-2004, 04:16 PM
zeus1's Avatar
i guess that answers what fuel was used i posted this below
Old 07-08-2004, 04:20 PM
Pie4Foo's Avatar
Default I assume these are the same?
<ul><li><a href="https://forums.audiworld.com/s4/msgs/1697654.phtml">Previous post</a></li></ul>
Old 07-08-2004, 04:39 PM
Lightweight-USPowah's Avatar
Default Some other dyno sheets off that dyno
<ul><li><a href="http://www.ktrperformance.com/services/Dyno_Graphs/graph_main.htm">The wall of fame, and shame..</a></li></ul>
Old 07-08-2004, 04:41 PM
Senior Member
Default Re: Did Franz fax that copy over to you!!
No. They emailed me a copy.
How do you know that crazy Fk?
Old 07-08-2004, 04:43 PM
Senior Member
Default Re: I assume these are the same?
Oops. Didn't see that below.
Yes they are the same.
Jeff
Old 07-08-2004, 05:16 PM
I speak to him very often, in person of course.
Old 07-08-2004, 05:17 PM
Hal_TT::CBP's Avatar
Default Nice pull. What's the 1/4 look like? And...
why in the h3ll hasn't someone done a work around for that whacky MAF other than to use a stock straightener which would flow even less than a Hitachi S4 stock housing?
Impressed... wondering how much more is in it.
Old 07-08-2004, 05:30 PM
Senior Member
Default We tracked a car with and w/o the wacky straightener-
Less than a .5 mph difference.
Could have just been changes in conditions.
I don't thing it makes a difference. Diego made a super custom "D-Flo" and only picked on .1 on the FATS test. Well within just a normal variation.
Jeff
Quick Reply: Stage 3+ dyno from KTR
