ugh.. stripped the head of the bolt while trying to put in a new inner cv boot
i stripped one of 6 the t-50 bolts. i got all the others loose, but i've been stuck all day trying to get the bolt off..
I Went to Ace with one of the bolts and the guy said try a pipe wrench.. it didnt work.. any ideas please THX
Answers inside...
Hah, finally my job actually applies elsewhere. First I always try filing 2 opposite sides of the bolthead down to get a good lock with vicegrips. If that doesnt work I break a small hacksaw blade (to allow for cutting in confined spaces) and cut a line down the middle of the bolthead. Then I use a size 3 flathead down the line I made. If that doesnt work I use a "screw removal tool" sometimes called an "ez out" set. There like $10 at home depot (and come with instructions). To use that, you drill a small hole down into the bolt and then use the "ez out" bit w/reverse threads to get it out.
