What do you think? 2 of 6 plugs oily.
<center><img src="http://s4.thefarnys.com/Misc/_w/IMG_5420_JPG.jpg"></center><p>both sides looked the same, i.e. cyl 2 and 5. these plugs had been in there for 15k. why just those two?
<img src="http://s4.thefarnys.com/Misc/_w/IMG_5418_JPG.jpg">
<img src="http://s4.thefarnys.com/Misc/_w/IMG_5417_JPG.jpg">
Well, either the gaskets were messed up, or the area of the heads/vc's are warped...
I don't think that any immediate damage will occur. Worst case scenario if enough oil gets in the valley it could destroy the plug. Other than that, I can't think of anything else. Also, since there is no oil on the threads or the electrode/tip area, it doesn't look like you have leaky cylinders.
No problem, sir. Also, if you look down into the spark plug valley, you should be able to see if
there is oil coming from the VC-head union where the gasket resides. I had the same problem before I replaced my gaskets.
then it's oil from the valve cover gasket change (or before it)
don't worry about it .. it could also have been there form before .. u haven't touch the plugs in long time so it most likely it occurred before the gaskets were changed and whoever did it did not clean in there that's all .
think about it:
15k ago - plugs.
5k ago - valve cover gaskets.
think about it:
15k ago - plugs.
Most likely the gaskets, but warpping is not ruled out.
I recommend that you check for warppage, in whatever way the presure test them... blah blah...
You do not want to have to take it apart again.
pink shrimp
12
02-28-2008 04:19 PM
Lexius
12
01-08-2008 06:54 PM
Onebad S4
10-06-2007 09:58 AM
Jargen
03-26-2007 11:28 AM
jhchoi01
11-09-2005 08:50 PM
