LED Headlight Adjustment
Anyone know if it's possible to adjust the height of the LED headlights? Mine have a lower throw than my Infiniti and my wife's BMW and it really cuts down on the night time visibility without having to use the high beams (which also aren't very high in comparison).
I know there is a way but I cant find the thread anymore that had the way to do it. It was a post in one of the "Lowering with VCDS" threads. Honestly dont remember if it was here or Audizine. I need to find it also because I have to adjust mine as well. If you come across it before I do, please share it.
There are screws to adjust just like any headlights.. One is left-right the other is up-down. They are not hard to find.
Headlights have three adjusters. There one that's usually on the lower outside that is the pivot and the in-out adjustment. There is one on the inside that is the left-right. One somewhere along the top that is the up-down. The pivot could be in a different location but adjustments are based on a triangular shape.
I find a brick/block wall is handy when adjusting or checking light alignment. When my wife goes into the craft or fabric shop, I'll go around back and put the nose of the car near a block wall. Note where the beams hit and back up slowly to see if they move. High beams should stay pretty much where they start from.
