S6 (C7 Platform) Discussion Discussion forum for the C7 Audi S6 produced from 2012 - 2017
what are adaptive brake lights?
Old 01-07-2014, 09:02 PM
rickymp's Avatar
Default what are adaptive brake lights?
And import CD 's? Can you get oil temp and turbo boost with vag com?
Old 01-07-2014, 11:11 PM
tenspeed's Avatar
When you brake normally, the back lights go on as normal; when you brake in an emergency, they blink several times per second to warn the cars behind.
Old 01-08-2014, 11:42 AM
rickymp's Avatar
Is that the normal setting or do you have to program it?
Old 01-08-2014, 11:55 AM
tenspeed's Avatar
You might have to buy a BMW, Mercedes-Benz or Volvo. I haven't heard of any Audi models that have them.
Old 01-08-2014, 12:10 PM
snagitseven's Avatar
Actually, I believe you can add the emergency braking behavior with the VCDS Vag-Com:
Enable Adaptive brake lights
[46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
Bit 0 – Emergency Brake Flashing via Turn Lights active - check box
Bit 1 – Emergency Brake Flashing via Brake Lights active - check box
I haven't tried either of the options but apparently others have had success.
Old 01-08-2014, 12:22 PM
tenspeed's Avatar
Thank for the good info. I usually tap the brake pedal several times when I predict trouble ahead on the highway. I did it yesterday when traveling near the Rochester NY airport that is known for white outs from blowing snow and saw many brake lights ahead. A RIT student lost her life in a multi-car accident in the same area a few winters ago.
Old 01-08-2014, 06:27 PM
Grapeking's Avatar
Correct. Works as advertised, in 'panic stop' situations.
Old 01-09-2014, 05:27 AM
AudiQ5sleeper's Avatar
it only activates if you do a hard braking so called emergency braking. its a neat feature that catches drivers eyes on the road.
Old 01-09-2014, 11:29 AM
mikec7s6's Avatar
I have it enabled on mine, but never knew or been able to check if they actually work.
Old 03-25-2014, 05:48 AM
DB22's Avatar
Does anyone know what triggers it? Is it -'ve G or brake pedal pressure or?
I enabled it but I have not seen it work, do I really have to stomp on the brakes?
I noticed a Smart car with them and they flashed Every time he braked even if it was a slight slowing.
Quick Reply: what are adaptive brake lights?
