S6 (C7 Platform) Discussion Discussion forum for the C7 Audi S6 produced from 2012 - 2017
VCDS Parking Brake Changes
Old 08-04-2013, 10:56 AM
gatorguy7's Avatar
Default VCDS Parking Brake Changes
The security code that comes up for Parking Brake - 53 and preventing me from making any changes. Has anyone had problems on their S6 turning off the parking brake warnings and requirement to press the brake pedal? Any reason why this would be different from the A6-4F?
Old 08-04-2013, 10:59 AM
nobbyv's Avatar
Turned mine off no problem. Not 100% sure, but doesn't VCDS generate a security code for you for this? Roll over the box with your mouse slowly, and I think you'll see it.
Old 08-04-2013, 11:17 AM
gatorguy7's Avatar
Yep, it comes up with the popup just like for everything else. It just doesn't accept the code. Would you or anyone else mind checking their code is the same that comes up with mine? 01437 is what it gives me.
Old 08-04-2013, 02:05 PM
Dr Chill's Avatar
Had no trouble with mine. I was hoping to figure out a way for the EPB to automatically activate when in park, but I tried activating automatic parking brake-automatic, shift P to EPB, and automatic parking brake for selector lever position P and none of these worked.
Old 08-04-2013, 02:29 PM
gatorguy7's Avatar
With the engine still on you mean?
Old 08-04-2013, 02:38 PM
Dr Chill's Avatar
Those were each channels that I activated in the adaptation menu under parking brake module in vagcom. None turned the epb on when I moved gear lever from drive to park.
Old 08-26-2014, 08:29 PM
Richard Solomon's Avatar
Did you ever resolve this? I'm seeing the same thing, though I've not yet been out for a test drive since picking "Shift P to EPB" which most sites say is the correct one.
Old 08-28-2014, 06:03 PM
No joy here either, and I'm starting to suspect why...
blazej01
03-20-2019 05:27 PM
uxk8396
Q5/SQ5 MKII Discussion
01-17-2019 12:30 PM
n4matx
VAG-COM Discussion
03-04-2015 02:53 AM
wfroehlich
07-06-2012 12:29 PM
Quick Reply: VCDS Parking Brake Changes
