VAG-COM Discussion
TPMS and DRL
Old 10-17-2016, 06:20 PM
eshan's Avatar
Default TPMS and DRL
hello every one does any one know how to disable tpms on audi q5 09 through vagcom. my q5 comes with direct tpms on rims and also how to covert drl to high or low beam or to fog light thanks in advance.
Old 10-18-2016, 06:58 PM
eshan's Avatar
bump
Old 12-03-2016, 08:09 AM
Nightlifephantom's Avatar
I believe you have to go into possibly the "Instruments" control module in VCDS. There should be an option to disable "Tire Pressure Monitoring". And I also believe you have to locate the fuse box that holds the fuse for the Tire Pressure Monitoring and remove the fuse.
I own an A6 but I'm pretty sure it is a similar process.
Old 12-03-2016, 06:49 PM
raj99's Avatar
I wouldn't make such an assumption...since the Q5 MMI differs from that of the C6. OP, I'd recommend you post in the actual Q5 forum and SEARCH.
280BlackPearl
A6 (C8 Platform) Discussion
12-28-2018 03:08 PM
Njsalazar
A4 (B8 Platform) Discussion
11-19-2018 02:26 PM
09S5BlueMan
06-10-2018 08:26 PM
mp-avant
03-06-2011 10:34 AM
sandreasson
Audi allroad
09-06-2004 12:49 AM
Quick Reply: TPMS and DRL
