VCDS - ABS module test
If anyone can help, please post 4 screenshoots from VCDS at 03-ABS Brakes -->> Meas. Blocks - 08 -->> Group 80, Group 81, Group 125 and Group 126. I want to compare with my data on 4E0-910-517 ABS module.
Sorry, I don't have it. But...did you run VCDS self test of module by chance? And now (or already), it codes as defective? If so, it's done AFAIK.
I have no error codes but Brake, ABS and ESP warning lights are on(from the first day when I've bought the car). I thing come cables are reversed on ABS module connector.
On Group 81 I have "XXXXXXXXXXXXXXXXXXXX" and I think it should be VIN there.
On Group 125 , according to label file, on 2'nd field it should be Transmission but i have Engine; and on 3'rd field It should be Engine, but i have Transmission
On group 126, according to label file, on 4'th field it should be Level Control System, but I have N/A.
I want to compare with other car.
Got it. Don't run self test FWIW unless ABS already coded out as defective. Seems to induce it, or at least did in past.
Hope you get answers you need. From seeing those kinds of lights and the posts, as usual consider the lowly brake light switch, especially if yours was an easy year one. Would be really odd for pin out to be messed up unless it was in an accident or some such and an end connector had to be replaced.
Perhaps more likely coding issues if someone played there. Besides looking at the VCDS module level coding on screen, you would try to find someone w/ same year, country and equipment as yours--probably especially the motor in this context. Sometimes if you search for fun scans people have posted up for some unrelated reason, you can find them Mine was a USA W12 so I would not rely on that for example for coding on a 4.2, even if USA. If not clear, using mine as an example, it says (from an old scan):
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 C HW: 4E0 614 517 BD
Component: ESP 5.7 allrad H44 0330
Coding: 0007637
Shop #: WSC 26131 000 00000
No fault code found.
With known correct coding for your year, country, motor, etc, compare your coding line to a known good one. For example, someone w/ a USA 2006 W12 probably would also see 0007637, and likewise should probably see the same HW and SW revision levels.
Coding: 0007637
No errors on any modules on the car, all ABS sensors are working, even the brake switch, and brake presure sensor. ABS and ESP are working well(both systems were tested on snow), so it looks to be communication problem between modules, because the modules are independently working well.
Unfortunately I didn't received an answer. The only two ways to get a valid answer are:
1. A confirmation that the values that I read are good or not.
2. Screenshoots that I've requested.
Thank you for understanding
other modules can throw the ABS offline..... this might be dumb but check the brake pads in the front and also the rear pads, check the fluid level,
here is an over view of the system
As I said, ABS and all modules are online, and working well. I just have some lights in dashboard, and some parameters that is PROBABLY incorrect. That's what I want to check.
Please, if someone can post screenshoots from VCDS at 03-ABS Brakes -->> Meas. Blocks - 08 -->> Group 80, Group 81, Group 125 and Group 126.
With all kindness, no other answers will be useful for me.
