Q7 Rough Idle
Q7 Rough Idle
Hi, maybe somebody can help me decipher this.. I have an 07 Q7 4.2, lately the car has cranked a bit longer during a cold start then runs very rough when the car becomes hot. Thanks! Here is the scan..
Wednesday,11,January,2017,09:47:15:34262
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 17.1.0.0
Data version: 20170106 DS267.0
Ross-Tech: Home
VIN: WA1AV74L97D057233 License Plate:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
55 56 61 62 65 6D 6F 72 77
VIN: WA1AV74L97D057233 Mileage: 202900km-126076miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 079-907-560-BAR.clb
Part No SW: 4L0 910 560 C HW: 4L0 907 560 A
Component: 4.2l V8/4V 0060
Revision: 71H39--- Serial number:
Coding: 01210009190F0160
Shop #: WSC 20833 002 1048576
VCID: 285F8F3E9B76CD01A7-807C
5 Faults Found:
001090 - EVAP Emission Control Sys
P0442 - 001 - Small Leak - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 201542 km
Time Indication: 0
Date: 2016.12.08
Time: 09:19:57
Freeze Frame:
RPM: 1430 /min
Load: 31.0 %
Speed: 65.0 km/h
Temperature: 60.0°C
Temperature: 6.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.954 V
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 202040 km
Time Indication: 0
Date: 2016.12.18
Time: 14:09:53
Freeze Frame:
RPM: 728 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 100.0°C
Temperature: 62.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.081 V
004763 - Fuel Pressure Regulator Valve; Bank 2 (N276)
P129B - 004 - Open Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 0
Fault Frequency: 14
Reset counter: 255
Mileage: 202313 km
Time Indication: 0
Date: 2016.12.24
Time: 13:24:11
Freeze Frame:
RPM: 780 /min
Load: 18.8 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 24.0°C
Absolute Pres.: 1030.0 mbar
Voltage: 13.081 V
008569 - Bank 2; System Too Lean off Idle
P2179 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 202313 km
Time Indication: 0
Date: 2016.12.24
Time: 13:25:32
Freeze Frame:
RPM: 701 /min
Load: 21.6 %
Speed: 9.0 km/h
Temperature: 94.0°C
Temperature: 26.0°C
Voltage: 12.954 V
000135 - Fuel Rail/System Pressure
P0087 - 008 - Too Low - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 202625 km
Time Indication: 0
Date: 2017.01.03
Time: 09:39:53
Freeze Frame:
RPM: 1986 /min
Load: 54.9 %
Speed: 54.0 km/h
Temperature: 96.0°C
Temperature: 9.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.589 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FH HW: 09D 927 750 FH
Component: AL 750 6A 0959
Revision: 00H52000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 79F99A7A305C848988-802C
No fault code found.
Address 03: ABS Brakes Labels: 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0017457
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100564407
Coding: 0000131
Shop #: WSC 08354 444 84041
VCID: 63C5D812A2D06E59B2-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 308J.067508945
Coding: 0002003
VCID: 377D5C4246C852F93E-8062
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000001493398
Subsystem 3 - Serial number: 0127.01.100000000100010334ÿ
Subsystem 4 - Serial number: 010334ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---011 Serial number: 00000000078818
Coding: 0524328
VCID: 61C9D21AB8CC7C49A0-8034
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0114123
VCID: 306F675EA3A685C17F-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
1 Fault Found:
02746 - Bulb for Daytime Running Light; Right
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 202676 km
Time Indication: 0
Date: 2017.01.04
Time: 09:48:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 111 A HW: 4L0 035 111
Component: CD-Changer H41 0100
Revision: 00000000 Serial number: AUZ5ZBF3050425
Shop #: WSC 00000 000 00000
VCID: 1E33A9E6C93203B1DD-804A
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7J0559386
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 225
Mileage: 195827 km
Time Indication: 0
Date: 2016.08.14
Time: 08:35:22
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH39 0210
Revision: 03H39000 Serial number: 0038QD040WAA
Coding: 0014131
VCID: 2B5570328A80E6194A-807E
Subsystem 1 - Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 6332QSME1774431BD
Subsystem 3 - Serial number: 6342QSME17737721B
Subsystem 4 - Serial number: 6352QSME15064D6BN
Subsystem 5 - Serial number: 6362QSME176C0B3DV
Subsystem 6 - Serial number: 63734SME15062903R
Subsystem 7 - Serial number: 63834SME15063031L
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H03000 Serial number: 90026062820104
Coding: 0012242
VCID: 275D8C029668C279AE-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 H
Component: KOMBIINSTR. M73 H17 0120
Revision: 00600000 Serial number: 5HH31CLA6
Coding: 2641263
Shop #: WSC 01110 444 999999
VCID: 23459812E2502E59F2-8076
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06A140005
Coding: E5D7BE77303A02
Shop #: WSC 01127 444 123984
VCID: 6CD7B32E4F0E212103-8038
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082946
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 D
Component: MNS US H48 0960
Revision: 00000000 Serial number: 313JP067508271
VCID: 2E537926B99293316D-807A
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00000000 Serial number: @X
Coding: 0035531
VCID: 2F6D6422BE989A3966-807A
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01021092710000
Coding: 7632925
VCID: 3169625AA8AC8CC970-8064
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
03073 - Rear Lid Closed Sensor 1
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 5
Fault Frequency: 254
Reset counter: 95
Mileage: 196173 km
Time Indication: 0
Date: 2016.08.19
Time: 14:52:02
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H02 0150
Revision: PROD_01 Serial number: 00000000021115
Coding: 0000016
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000047047
Coding: 0012001
VCID: 5EB3E9E689B243B19D-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00000000 Serial number: f
Coding: 0035531
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000021
VCID: 29598A3A807CF409B8-807C
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH06 0002
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 388J.067560714
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000049714
Shop #: WSC 08215 444 54285
VCID: 64C7DB0EA7DE69614B-8030
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 341111B075
Coding: 344630393135313035442056413033343131313142303735
2 Faults Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 23
Reset counter: 255
Mileage: 187787 km
Time Indication: 0
Date: 2016.01.06
Time: 15:14:46
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 89
Mileage: 202546 km
Time Indication: 0
Date: 2016.12.30
Time: 23:05:48
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0035338
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700032769
Coding: 0062424
VCID: 224B9D16FD4A2751F9-8076
1 Fault Found:
02214 - Tire Pressure Warning
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 253
Reset counter: 0
Mileage: 196757 km
Time Indication: 0
Date: 2016.08.26
Time: 09:08:39
Freeze Frame:
(no units): 61.0
Temperature: 26.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD18.10.06--H21001001C0022ÿ
Subsystem 4 - Serial number: 1C0022ÿ
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002064552-----
Coding: 0003595
VCID: 264381069162DB7195-8072
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE15_SKB09H10 0180
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE15_SKB09H10 0180
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0035338
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007550812
Coding: 0010900
End-------------------------(Elapsed Time: 03:35)--------------------------
Ross-Tech: Home
5 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 201542 km
Time Indication: 0
Date: 2016.12.08
Time: 09:19:57
Freeze Frame:
RPM: 1430 /min
Load: 31.0 %
Speed: 65.0 km/h
Temperature: 60.0°C
Temperature: 6.0°C
Voltage: 12.954 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 202040 km
Time Indication: 0
Date: 2016.12.18
Time: 14:09:53
Freeze Frame:
RPM: 728 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 62.0°C
Voltage: 13.081 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 14
Reset counter: 255
Mileage: 202313 km
Time Indication: 0
Date: 2016.12.24
Time: 13:24:11
Freeze Frame:
RPM: 780 /min
Load: 18.8 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 24.0°C
Voltage: 13.081 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 202313 km
Time Indication: 0
Date: 2016.12.24
Time: 13:25:32
Freeze Frame:
RPM: 701 /min
Load: 21.6 %
Speed: 9.0 km/h
Temperature: 94.0°C
Temperature: 26.0°C
Voltage: 12.954 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 202625 km
Time Indication: 0
Date: 2017.01.03
Time: 09:39:53
Freeze Frame:
RPM: 1986 /min
Load: 54.9 %
Speed: 54.0 km/h
Temperature: 96.0°C
Temperature: 9.0°C
Voltage: 13.589 V
Coding: 0000504
Revision: 00H22001
Coding: 0017457
Coding: 0000131
Coding: 0002003
Coding: 0524328
Coding: 0114123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 202676 km
Time Indication: 0
Date: 2017.01.04
Time: 09:48:00
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 225
Mileage: 195827 km
Time Indication: 0
Date: 2016.08.14
Time: 08:35:22
Coding: 0014131
Coding: 0012242
Coding: 2641263
Coding: 0082946
Coding: 0035531
Coding: 7632925
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 95
Mileage: 196173 km
Time Indication: 0
Date: 2016.08.19
Time: 14:52:02
Coding: 0000016
Coding: 0012001
Coding: 0035531
Coding: 0000021
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 23
Reset counter: 255
Mileage: 187787 km
Time Indication: 0
Date: 2016.01.06
Time: 15:14:46
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 89
Mileage: 202546 km
Time Indication: 0
Date: 2016.12.30
Time: 23:05:48
Coding: 0035338
Coding: 0062424
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Reset counter: 0
Mileage: 196757 km
Time Indication: 0
Date: 2016.08.26
Time: 09:08:39
Freeze Frame:
(no units): 61.0
Temperature: 26.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0003595
Coding: 0035338
Coding: 0010900
This is what I see from your chart.
This sensor is causing everything to go crazy, It is also causing Bank 1 to have to much fuel cause the ECM is pushing more fuel in Bank 1 cause Bank 2 is not working right.
Below is a page from the manual for sensor (N276) for testing it is not hard at all just need a Muti meter.
Q7 - fuel pressure (276).pdf
On my Q7 one of the High Pressure Fuel Pumps went bad and it caused a boat load of fault codes! It may be a good idea to change out the other HPFP when the opportunity arises, as a preventive measure.
Running into same issues . . .
Running into the same issues on my Q7. Slow to start and rough driving. Did you replace the Fuel Pressure Sensor (N276) as well or just the engine mounted fuel pump?
The only thing I have done so far put in some fuel injector cleaner in it yesterday and no change. She takes about 5 seconds to turn over and she's sputtering some times when I start driving. But sometimes she starts right up and get very little sputtering when I drive. Was going to replace the fuel pressure sensor next but would love some advice on what you would do next.
Here's a list of what I'm getting for codes:
Friday,18,August,2017,17:14:28:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Ross-Tech: Home
VIN: WA1BY74L47D058964 License Plate:
Mileage: 201880km-125442mi Repair Order: 8-18-17
Scan: 01 02 03 05 07 08 09 0E 13 15 16 17 19 42 46 47 4F 52 55 56
61 62 65 6F 72 77
VIN: WA1BY74L47D058964 Mileage: 201880km-125442miles
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Cannot be reached 1100
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03H-906-032-BLV.lbl
Part No SW: 03H 906 032 BG HW: 03H 906 032 G
Component: Q7 3.6-FSI-LEV2 G00 0447
Revision: 5CH03--- Serial number:
Coding: 0001175
VCID: 68D8208F5B607C7EF5-803C
6 Faults Found:
P0087 - 002 - Too Low - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 199762 km
Time Indication: 0
Date: 2017.07.20
Time: 20:23:09
Freeze Frame:
RPM: 722 /min
Load: 27.4 %
Speed: 0.0 km/h
Temperature: 51.0∞C
Temperature: 27.0∞C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 201110 km
Time Indication: 0
Date: 2017.08.07
Time: 08:56:29
Freeze Frame:
RPM: 2059 /min
Load: 65.9 %
Speed: 37.0 km/h
Temperature: 74.0∞C
Temperature: 28.0∞C
Voltage: 14.097 V
008854 - Fuel Pressure Regulator Valve (N276)
P2296 - 001 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 13
Reset counter: 255
Mileage: 201114 km
Time Indication: 0
Date: 2017.08.07
Time: 09:02:52
Freeze Frame:
RPM: 1491 /min
Load: 33.3 %
Speed: 64.0 km/h
Temperature: 92.0∞C
Temperature: 24.0∞C
Voltage: 13.843 V
012408 - Throttle Control
P3078 - 002 - Airflow at Idle too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 201331 km
Time Indication: 0
Date: 2017.08.10
Time: 11:35:27
Freeze Frame:
RPM: 1013 /min
Load: 18.0 %
Speed: 41.0 km/h
Temperature: 92.0∞C
Temperature: 28.0∞C
Voltage: 13.970 V
000369 - Fuel Trim; Bank 1
P0171 - 001 - System Too Lean - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 201507 km
Time Indication: 0
Date: 2017.08.13
Time: 23:47:54
Freeze Frame:
RPM: 1716 /min
Load: 43.1 %
Speed: 58.0 km/h
Temperature: 88.0∞C
Temperature: 24.0∞C
Voltage: 13.716 V
000257 - Mass Air Flow Sensor (G70)
P0101 - 004 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 201531 km
Time Indication: 0
Date: 2017.08.14
Time: 01:24:00
Freeze Frame:
RPM: 1508 /min
Load: 71.7 %
Speed: 39.0 km/h
Temperature: 89.0∞C
Temperature: 21.0∞C
Voltage: 13.716 V
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4L0 910 156 C HW: 0AT 927 156
Component: AG6 0AT 3,6 FSI USA 0010
Revision: --H01--- Serial number: 4008281
Coding: 0000002
VCID: 295E658B80EA85762A-807C
1 Fault Found:
006231 - Load Signal
P1857 - 001 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 201531 km
Time Indication: 0
Date: 2017.08.14
Time: 01:24:04
Freeze Frame:
RPM: 1504 /min
RPM: 1504 /min
RPM: 1312 /min
(no units): 68.0
(no units): 55.0
Temperature: 75.0∞C
T.B. Angle: 20.8∞
Revision: 00H22001
Coding: 0033809
VCID: 2858608F9BE0BC7E35-807C
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 160
Mileage: 201531 km
Time Indication: 0
Date: 2017.08.14
Time: 01:24:01
Freeze Frame:
Count: 9984
Count: 8193
Count: 8193
Count: 49408
Revision: 31050601 Serial number: 10601100577027
Coding: 0000131
VCID: 63C237A3A2461F2620-8036
Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
Revision: 00000000 Serial number: 308JW067509066
Coding: 0002203
Shop #: WSC 00000 000 08192
VCID: 377AB3F3465E2386AC-8062
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001836152
Subsystem 3 - Serial number: 0106.05.110000000100010535ˇ
Subsystem 4 - Serial number: 010535ˇ
2 Faults Found:
02257 - Remote Control Receiver
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 168
Mileage: 183790 km
Time Indication: 0
Date: 2017.01.14
Time: 09:36:40
02244 - Button in Control Head is Stuck
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 158
Mileage: 201209 km
Time Indication: 0
Date: 2017.08.08
Time: 15:04:53
Freeze Frame:
Bin. Bits: 01000101
Bin. Bits: 0001000
Bin. Bits: 000
Revision: 00---012 Serial number: 00000030009435
Coding: 0524326
VCID: 61CE3DABB85A0D3632-8034
2 Faults Found:
00714 - Centre Right Vent Positioning Motor (V111)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 65
Reset counter: 120
Mileage: 201401 km
Time Indication: 0
Date: 2017.08.11
Time: 20:08:46
Freeze Frame:
Voltage: 12.00 V
Temperature: 27.0∞C
(no units): 113.0
(no units): 120.0
Temperature: 26.0∞C
02380 - Positioning Motor for Right Side Vent (V300)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 54
Reset counter: 160
Mileage: 201401 km
Time Indication: 0
Date: 2017.08.11
Time: 20:08:46
Freeze Frame:
Voltage: 12.00 V
Temperature: 27.0∞C
(no units): 131.0
(no units): 194.0
Temperature: 26.0∞C
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Coding: 0014123
VCID: 316E8DEBA83AFDB6E2-8064
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 201400 km
Time Indication: 0
Date: 2017.08.11
Time: 20:09:00
01494 - Bulb for Parking Lamps; Left (M1)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 201400 km
Time Indication: 0
Date: 2017.08.11
Time: 20:08:00
Part No SW: 4L0 910 110 B HW: 4L0 035 110
Component: MP3-Changer H43 0390
Revision: 00043000 Serial number: AUZ5ZBF1012934
VCID: 1E344657C9A472CE4F-804A
Address 13: Auto Dist. Reg
Cannot be reached
Revision: 03H39000 Serial number: 0038QD041H4X
Coding: 0014131
VCID: 2B529F838A169766D8-807E
Subsystem 2 - Serial number: 6332QSME177223579
Subsystem 3 - Serial number: 6342QSME18131C6DL
Subsystem 4 - Serial number: 6352QSME1818291BI
Subsystem 5 - Serial number: 6362QSME18103F7DQ
Subsystem 6 - Serial number: 63734SME1506205BV
Subsystem 7 - Serial number: 63834SME1506765B0
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenks‰ulenmodul H08 0230
Revision: 00H08000 Serial number: 90026062900316
Coding: 0002022
VCID: 66C42EB751746A0EC7-8032
Component: Lenkradmodul H07 0090
Part No SW: 4F0 910 900 C HW: 4L0 920 950 B
Component: KOMBIINSTR. M73 H11 0240
Revision: 00400000 Serial number: 4ZS73WTA6
Coding: 0531263
Shop #: WSC 08352 444 85769
VCID: 204878AFF3D0443E7D-8074
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 150
Mileage: 201504 km
Time Indication: 0
Date: 2017.08.13
Time: 22:27:53
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Revision: 00H06000 Serial number: 0900B06A21811A
Coding: E5579E77311202
VCID: 6CD05C9F4F98505E91-8038
2 Faults Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 105
Mileage: 201401 km
Time Indication: 0
Date: 2017.08.11
Time: 20:18:56
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 150
Mileage: 201561 km
Time Indication: 0
Date: 2017.08.14
Time: 10:39:32
Revision: 00000000 Serial number: r
Coding: 0035403
VCID: 2F6A8B93BE0EEB46F4-807A
Revision: 0020 --- Serial number: 01021392790000
Coding: 4225181
1 Fault Found:
02956 - Lamp in Trunk/Hatch Lid; Left
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 150
Mileage: 201520 km
Time Indication: 0
Date: 2017.08.14
Time: 00:12:44
Freeze Frame:
Bin. Bits: 001 000
Component: DSP-High AU716 H03 0150
Revision: PROD_01 Serial number: 00000000000389
Coding: 0000016
Revision: Serial number: 00000000048537
Coding: 0012001
VCID: 5EB40657892432CE0F-800A
Coding: 0035403
1 Fault Found:
02110 - Window Regulator Switch
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 150
Mileage: 201543 km
Time Indication: 0
Date: 2017.08.14
Time: 01:43:28
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Coding: 0000007
VCID: 3D76A1DB646209D676-8068
Revision: 00000000 Serial number: 388J6067562949
Coding: 0000002
Revision: -------- Serial number: 00000000055666
VCID: 64C034BFA748181ED9-8030
Component: von VA0 2610205634
Coding: 344630393135313035442056413032363130323035363334
Coding: 0035338
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 150
Mileage: 201519 km
Time Indication: 0
Date: 2017.08.14
Time: 00:07:29
Revision: 00050100 Serial number: 00000900034292
Coding: 0062424
VCID: 224C72A7FDDC562E6B-8076
2 Faults Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 190445 km
Time Indication: 0
Date: 2017.05.16
Time: 15:21:48
Freeze Frame:
(no units): 58.0
Voltage: 14.10 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 190438 km
Time Indication: 0
Date: 2017.05.16
Time: 13:36:38
Freeze Frame:
(no units): 0.0
Voltage: 14.00 V
(no units): 142.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Revision: AAH05061 Serial number: 002082087-----
Coding: 0000009
VCID: 26446EB791F4AA0E07-8072
Coding: 0035338
Cannot be reached
End-------------------------(Elapsed Time: 03:38)--------------------------
Ross-Tech: Home
61 62 65 6F 72 77
Coding: 0001175
6 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 199762 km
Time Indication: 0
Date: 2017.07.20
Time: 20:23:09
Freeze Frame:
RPM: 722 /min
Load: 27.4 %
Speed: 0.0 km/h
Temperature: 51.0∞C
Temperature: 27.0∞C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 201110 km
Time Indication: 0
Date: 2017.08.07
Time: 08:56:29
Freeze Frame:
RPM: 2059 /min
Load: 65.9 %
Speed: 37.0 km/h
Temperature: 74.0∞C
Temperature: 28.0∞C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 13
Reset counter: 255
Mileage: 201114 km
Time Indication: 0
Date: 2017.08.07
Time: 09:02:52
Freeze Frame:
RPM: 1491 /min
Load: 33.3 %
Speed: 64.0 km/h
Temperature: 92.0∞C
Temperature: 24.0∞C
Voltage: 13.843 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 201331 km
Time Indication: 0
Date: 2017.08.10
Time: 11:35:27
Freeze Frame:
RPM: 1013 /min
Load: 18.0 %
Speed: 41.0 km/h
Temperature: 92.0∞C
Temperature: 28.0∞C
Voltage: 13.970 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 201507 km
Time Indication: 0
Date: 2017.08.13
Time: 23:47:54
Freeze Frame:
RPM: 1716 /min
Load: 43.1 %
Speed: 58.0 km/h
Temperature: 88.0∞C
Temperature: 24.0∞C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 201531 km
Time Indication: 0
Date: 2017.08.14
Time: 01:24:00
Freeze Frame:
RPM: 1508 /min
Load: 71.7 %
Speed: 39.0 km/h
Temperature: 89.0∞C
Temperature: 21.0∞C
Voltage: 13.716 V
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 201531 km
Time Indication: 0
Date: 2017.08.14
Time: 01:24:04
Freeze Frame:
RPM: 1504 /min
RPM: 1504 /min
RPM: 1312 /min
(no units): 68.0
(no units): 55.0
Temperature: 75.0∞C
T.B. Angle: 20.8∞
Revision: 00H22001
Coding: 0033809
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 160
Mileage: 201531 km
Time Indication: 0
Date: 2017.08.14
Time: 01:24:01
Freeze Frame:
Count: 9984
Count: 8193
Count: 8193
Count: 49408
Coding: 0000131
Coding: 0002203
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 168
Mileage: 183790 km
Time Indication: 0
Date: 2017.01.14
Time: 09:36:40
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 158
Mileage: 201209 km
Time Indication: 0
Date: 2017.08.08
Time: 15:04:53
Freeze Frame:
Bin. Bits: 01000101
Bin. Bits: 0001000
Bin. Bits: 000
Coding: 0524326
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 65
Reset counter: 120
Mileage: 201401 km
Time Indication: 0
Date: 2017.08.11
Time: 20:08:46
Freeze Frame:
Voltage: 12.00 V
Temperature: 27.0∞C
(no units): 113.0
(no units): 120.0
Temperature: 26.0∞C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 54
Reset counter: 160
Mileage: 201401 km
Time Indication: 0
Date: 2017.08.11
Time: 20:08:46
Freeze Frame:
Voltage: 12.00 V
Temperature: 27.0∞C
(no units): 131.0
(no units): 194.0
Temperature: 26.0∞C
Coding: 0014123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 201400 km
Time Indication: 0
Date: 2017.08.11
Time: 20:09:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 201400 km
Time Indication: 0
Date: 2017.08.11
Time: 20:08:00
Cannot be reached
Coding: 0014131
Coding: 0002022
Coding: 0531263
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 150
Mileage: 201504 km
Time Indication: 0
Date: 2017.08.13
Time: 22:27:53
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 105
Mileage: 201401 km
Time Indication: 0
Date: 2017.08.11
Time: 20:18:56
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 150
Mileage: 201561 km
Time Indication: 0
Date: 2017.08.14
Time: 10:39:32
Coding: 0035403
Coding: 4225181
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 150
Mileage: 201520 km
Time Indication: 0
Date: 2017.08.14
Time: 00:12:44
Freeze Frame:
Bin. Bits: 001 000
Coding: 0000016
Coding: 0012001
Coding: 0035403
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 150
Mileage: 201543 km
Time Indication: 0
Date: 2017.08.14
Time: 01:43:28
Coding: 0000007
Coding: 0000002
Coding: 0035338
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 150
Mileage: 201519 km
Time Indication: 0
Date: 2017.08.14
Time: 00:07:29
Coding: 0062424
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 190445 km
Time Indication: 0
Date: 2017.05.16
Time: 15:21:48
Freeze Frame:
(no units): 58.0
Voltage: 14.10 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 190438 km
Time Indication: 0
Date: 2017.05.16
Time: 13:36:38
Freeze Frame:
(no units): 0.0
Voltage: 14.00 V
(no units): 142.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0000009
Coding: 0035338
Cannot be reached
@testarossaguy did you replace it yourself? If yes how difficult was it? I need to change mine and not sure if I should attack it myself or just throw my hands up and have the mechanic do it.
kamrooz
10-30-2017 07:13 PM
nunopresa
05-08-2017 02:00 AM
nunopresa
05-06-2017 09:33 AM
