Home link / LiftMaster Problem
Hello all,
On my A4 when I press the home link button to open the garage door I need to be right up against the door for it to work, on my 17 Q7 I can open the door from my neighbors driveway 250' away! While I don't need or expect that on my A4 I'd like to know if others are experiencing this issue or should I visit the dealer? I've erased the program and reprogrammed it 2 times and there is no change, any ideas? The garage door openers are a little over a year old.
I have great range on mine. It easily activates the garage door as I am on my street approaching the driveway. I have a metal, windowless garage door and a 20 year old Craftsman (Chamberlain) unit.
I'm trying to hang on to this old opener as long as I can. No connectivity problems and it works great. It has quit on me once, about 3 years ago, but I was able to breathe new life into it be rebuilding the gear drive in it. Amazon sells a rebuild kit for $20. Saved me from having to replace it.
Hello all,
2 identical openers, bought at the same time, Q7 can open either door from a distance, A4 needs to be within 10' of the garage doors. Both vehicles are coded to open either door.
Hmmm maybe check the antenna (little wire hanging down) and make sure that it is pointed towards the road
Checked both of them, both hanging down, same position, but since the Q works both fine and the A doesn't it leads me to believe it's something up with the A. Thinking of extending the antenna wire to see if that would help on the openers.
