Audi Q7 2017 Parking Aid camera not working
Old 02-24-2017, 03:39 AM
abhizen's Avatar
Default Audi Q7 2017 Parking Aid camera not working
When I shift to reverse, the front and rear camera do not show the pic, only a car image is displayed with sesnsor indicating of any obstacles...
Old 02-24-2017, 05:22 AM
lentiman's Avatar
could be a unplugged connector. Have your dealer check, it's under warranty. Also, use the correct Q7 forum. They may have seen this.
Old 02-24-2017, 03:27 PM
Ultimate Keyboard Warrior
Force-1's Avatar
Q7 MKII Discussion - AudiWorld Forums
Old 04-03-2017, 05:51 PM
ayoung88's Avatar
I have the same problem. Did you find out why?
Old 02-18-2018, 05:37 AM
digitaldaryl's Avatar
I have a 2017 Q7 and the cameras, sensors all stopped working. When I put go into reverse the screen would go black and no cameras or sensors would work. After two days the systems apparently "reset" itself overnight.
Old 02-18-2018, 06:04 AM
lentiman's Avatar
Please see second and third post.
Old 07-06-2018, 08:48 PM
Dklewless's Avatar
Default Parking camera issue fixed
i just got my Q7 back from the dealership. The dealer found a diagnostic trouble code for Control Module for Instrument panel insert on optical data bus. No communication sporadic.
They removed and replaced the instrument cluster. Apparently the camera data is routed through the cluster and goes to the center console monitor.
they cleared the fault and Test drove the car. No other faults came up. I hope this fixed it.
Good luck with your repair.
Old 07-07-2018, 12:20 PM
Force-1's Avatar
RIF
Old 01-25-2024, 10:41 AM
Q7 TDI - 2015's Avatar
My camera wasn't working, it turns out that the camera won't work if one of the sensors is bad, my right front center had a code, I replaced it, and now the camera works fine.
Old 01-25-2024, 05:23 PM
'10Q7TDI_Prestige''s Avatar
Good tip!
Scanning the car is always the best place to begin, as it will often help you find a root-cause issue. There is however, also a toggle for the screen view control when you shift into R, which allows you to change the MMI screen view between different modes, (towing line-up, car image/distance sensor overview only, front camera...if s-line equipped, including sideviews, etc., etc.), etc. Loss of access completely to parking assist, as well as to specific views/functions in the park-assist can also be linked to coding changes to the park-assist feature directly or indirectly from Green Menu coding changes, etc.
A quick perusal of the owner's guide/manual will reveal multiple convenience functions/features most owners are not aware of on this car.
faststeve
Q5/SQ5 MKI (8R) Discussion
15
01-16-2021 09:36 AM
buldysor
A4 (B9 Platform) Discussion
07-08-2020 04:44 AM
Devo1010
A7
01-14-2019 08:14 PM
userdhp
12-17-2008 05:45 AM
Quick Reply: Audi Q7 2017 Parking Aid camera not working
