Water ingress in ECU area Audi A4 renders it completely dead!
Old 02-27-2017, 03:23 AM
waterboy's Avatar
Default Water ingress in ECU area Audi A4 renders it completely dead!
Help pls. Car won't start and garage say they need to strip it down to check why. ECU box sent off to test as it was flooded with rainwater. Came back fine, thats not the problem. Looking to get an auto electrician to check but not covered on insurance. Anyone had this problem before where car is completely dead. no electrics, won't start, no fault codes, nothing?! Thx
Old 02-27-2017, 06:55 AM
W261w261's Avatar
How did the car get so wet? I assume you have tested for voltage at the battery?
Old 02-27-2017, 11:18 AM
lyleswk's Avatar
Typically, clogged drains in the cowl area. Pretty common if you car is kept outside under foliage. I tried to find the exact locations, but I believe there is one under the ECU, one under the battery, and one under the cabin filter, but not completely sure.
Old 02-28-2017, 01:56 AM
old guy2's Avatar
Start by replacing the ECU power control relay (219) located underneath the ECU.
Old 02-28-2017, 05:13 AM
lyleswk's Avatar
Thanks OG. You're a wealth on info on our cars.
Christiangarcia
Audi Original "S" Cars
11
03-03-2011 06:50 AM
RussB
03-10-2006 06:35 PM
unselfishly
08-20-2005 11:16 AM
Quick Reply: Water ingress in ECU area Audi A4 renders it completely dead!
